[STATSGRASS] moving-window analysis
Edzer J. Pebesma
e.pebesma at geo.uu.nl
Wed Jun 6 14:43:31 EDT 2007
Well, package gstat provides linear regression within a local search
neighbourhood defined either by distance (circular window) or by nr of
nearest neighbours. Is that what you want?
try:
library(gstat)
data(meuse)
data(meuse.grid)
coordinates(meuse)=~x+y
gridded(meuse.grid) = ~x+y
x = krige(log(zinc)~sqrt(dist),meuse,meuse.grid,maxdist=600)
image(x)
Edzer
Carlos "Guâno" Grohmann wrote:
> Basic moving-window (ie, mean, stddev etc) is easy. The tricky
> question is how to make a best-fit least squares inside that moving
> window? I mean that it has to be a general function, so you can choose
> the size of the window.
> Carlos
> On 6/6/07, G. Allegri <giohappy at gmail.com> wrote:
>> In my experience the easier way to realize a moving-window analysys
>> between rasters is to use r.mapcalc. I never did it in R. I knew that
>> caTools package could do it someway... but I think using r.mapcla is
>> more straightforward.
>> Look at this nice article:
>> http://casoilresource.lawr.ucdavis.edu/drupal/node/221
>> Giovanni
>> 2007/6/6, Carlos Guâno Grohmann <carlos.grohmann at gmail.com>:
>> > > What kind of data do you have?
>> > DEMs, some LiDAR, maybe
>> > > > Hello. I was thinking what would be the best way to do a
>> moving-window
>> > > > analysis where the result is the deviation of values about a
>> best-fit
>> > > > plane?
>> > > > some modification to r.in.xyz?
>> > > > r.mapcalc?
>> > > > R? (which package, function..?)
>> > > > thanks
>> > > > Carlos Henrique Grohmann - Guano
>> > > > Visiting Researcher at Kingston University London - UK
>> > > > Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
>> > > > Linux User #89721 - carlos dot grohmann at gmail dot com
>> > > > _________________
>> > > > "Good morning, doctors. I have taken the liberty of removing
>> Windows
>> > > > 95 from my hard drive."
>> > > > --The winning entry in a "What were HAL's first words" contest
>> judged
>> > > > by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
>> > > > _______________________________________________
>> > > > statsgrass mailing list
>> > > > statsgrass at grass.itc.it
>> > > > http://grass.itc.it/mailman/listinfo/statsgrass
>> > _________________
>> > "Good morning, doctors. I have taken the liberty of removing Windows
>> > --The winning entry in a "What were HAL's first words" contest judged
More information about the grass-stats
