[GRASS-stats] R-GRASS error: "all connections are in use"
Jarosław Jasiewicz jarekj at amu.edu.pl
Fri Apr 25 02:18:35 EDT 2008
Hi
This message apeeared on the begining of the loop or in somewhere in the
iteration
please type the full command (full loop) you have used
uan Manuel Barreneche pisze:
> Hello list,
> I'm currently using R version 2.5.0 (2007-04-23) in conjunction with
> GRASS6.2.2.
> My goal is to use a loop to extract data from rasters created in grass
> (a different raster in each simulation, created with r.cost using a
> unique cost surface raster, which is deleted every time in order to
> free disk space).
> Percent complete:  100%
> r.out.bin complete.
> REMOVE [nombre]
>  raster
>  header
>  category
>  color    MISSING
>  history
>  misc
>  fcell    MISSING
>  g3dcell  MISSING
> Creating BIL support files ...
> Header File = /home/mastermind/GRASSDATA/prueba/wordlclim/.tmp/torre11b1-4/nombre.hdr
> World File = /home/mastermind/GRASSDATA/prueba/wordlclim/.tmp/torre11b1-4/nombre.wld
> Exporting Raster as integer values (bytes=2)
> Using the Current Region settings ...
> north=-34.474986
> south=-34.966653
> east=-55.866644
> west=-56.558311
> r=59
> c=83
> Porcentaje completado:  100%
> r.out.bin complete.
> Error in file(paste(fname, "wld", sep = "."), "r") :
> In addition, after this message every time i try a help comand (such
> as ?file, ?rbind, etc...) i get the same message:
> Error in file(con, "r"): all connections are in use
> I've been working with R and GRASS for about 9 months and I'm not much
> of a specialist, so i'm really lost here, does anybody have a clue
> about the solution of this problem?
> many thanks,
> Juan Manuel
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats mailing list
