[GRASS-stats] R-GRASS error: "all connections are in use"
Juan Manuel Barreneche
jumanbar at gmail.com
Fri Apr 25 17:02:34 EDT 2008
Well, thanks to you all, the problem was fixed. It turned out that
RB's suggestion was right (i updated R, only). I apologize for sending
only partial information (in fact it was because of a distraction that
i didn't put all the script, etc. in the email).
One thing caugth my attention though: every time i call readRAST6 a
warning message apears, saying:
> warnings()
$`closing unused connection 3 (gsub(" ", ":", l8))`
NULL
I suppose this is exactly the improvement that Roger B. pointed out in
his reply, and i just didn't give much importance to it. Please let me
know if there is something important to take into consideration...
Thanks again,
JM
On Fri, Apr 25, 2008 at 3:52 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Fri, 25 Apr 2008, Jarosaw Jasiewicz wrote:
> > Hi
> > This message apeeared on the begining of the loop or in somewhere in the
> iteration
> > please type the full command (full loop) you have used
> > uan Manuel Barreneche pisze:
> > > Hello list,
> > > I'm currently using R version 2.5.0 (2007-04-23) in conjunction with
> > > GRASS6.2.2.
> Please always include the output of sessionInfo(), in addition to the R
> version. spgrass6 is updated from time to time, so it may be that you are -
> for example - using an obsolete route, although you are using BIL files, so
> I guess that this is readRAST6() in a loop, as Jarek suggested.
> Specifically, I think that this problem was solved in R-2.6.0 - the
> relevant news item is:
> o Connections will be closed if there is no R object referring to
> them. A warning is issued if this is done, either at garbage
> collection or if all the connection slots are in use.
> which means that functions do not need to close them explicitly.
> Roger
> > > My goal is to use a loop to extract data from rasters created in grass
> > > (a different raster in each simulation, created with r.cost using a
> > > unique cost surface raster, which is deleted every time in order to
> > > free disk space).
> > > Percent complete: 100%
> > > r.out.bin complete.
> > > REMOVE [nombre]
> > > raster
> > > header
> > > category
> > > color MISSING
> > > history
> > > misc
> > > fcell MISSING
> > > g3dcell MISSING
> > > Creating BIL support files ...
> > > Header File =
> > > /home/mastermind/GRASSDATA/prueba/wordlclim/.tmp/torre11b1-4/nombre.hdr
> > > World File =
> > > /home/mastermind/GRASSDATA/prueba/wordlclim/.tmp/torre11b1-4/nombre.wld
> > > Exporting Raster as integer values (bytes=2)
> > > Using the Current Region settings ...
> > > north=-34.474986
> > > south=-34.966653
> > > east=-55.866644
> > > west=-56.558311
> > > r=59
> > > c=83
> > > Porcentaje completado: 100%
> > > r.out.bin complete.
> > > Error in file(paste(fname, "wld", sep = "."), "r") :
> > > In addition, after this message every time i try a help comand (such
> > > as ?file, ?rbind, etc...) i get the same message:
> > > Error in file(con, "r"): all connections are in use
> > > I've been working with R and GRASS for about 9 months and I'm not much
> > > of a specialist, so i'm really lost here, does anybody have a clue
> > > about the solution of this problem?
> > > many thanks,
> > > Juan Manuel
> > > _______________________________________________
> > > grass-stats mailing list
> > > grass-stats at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-stats
> Roger Bivand
> Economic Geography Section, Department of Economics, Norwegian School of
> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
