[GRASS-stats] Heuristic assignment of NODATA value in package spgrass6
Rainer M Krug r.m.krug at gmail.com
Fri Aug 1 12:17:47 EDT 2008
I am confronted with the situation where a raster in grass has only
NULL values.
As I am using grass and R to do simulations, this can happen under
certain situations.
I am doing calculations with these layers also in R ands consequently
I am loading these layers with readRAST6(). But when all values are
NULL in the raster, I get an error message:
> readRAST6("HSericea_seedsDisperse_2007")
ERROR: Invalid value for null (integers only)
Error in readBinGrid(rtmpfl11, colname = vname[i], proj4string = p4,
integer = to_int) :
 no such file:
/home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/.tmp/ecolmod/HSericea_seedsDisperse_2007
I would therefore suggest that in this case, an arbitrary value is
assigned to the NODATA  argument to avoid this error.
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
More information about the grass-stats mailing list
