[GRASS-stats] Specify attribute column in SpatialPolygonsDataFrame
	when using overlay(grd, polyg)
    Rainer M Krug
    r.m.krug at gmail.com
    Sat Aug  9 08:24:02 EDT 2008
Hi
I have a SpatialGridDataFrame-class (grd) and a
SpatialPolygonsDataFrame (polyg) with more then one attribute columns,
i.e.
names(slot(polyg, "data"))
results in
"a", "b", "c", ... "z"
I want to use overlay to convert polyg into a grid, by assigning the
values of attribute column "d" to the grid.
Is it possible to specify the column name in the following overlay statement:
d <- overlay(grd, polyg)
grd[[1]] <- d
results in the values of the attribute column "d" in grd[[1]]?
Thanks,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
More information about the grass-stats
