[GRASS-stats] using LOESS on spatial data
Jarek Jasiewicz jarekj at amu.edu.pl
Sat Jan 19 13:55:47 EST 2008
> Like most non- and semi-parametric methods, that depends on your
> definition of proper. In mgcv, gam() uses cross-validation to choose
> the smoothing parameters. You might do something similar to choose the
> span= argument. If you have traning and testing data sets, you can see
> how well loess predicts the test data given the training data.
> Hope this helps,
> Roger
tahanks. I will follow.
regards
Jarek
More information about the grass-stats mailing list
