[GRASS-stats] Rdbi Error in loadNamespace
    bks at centrum.cz
    bks at centrum.cz
    Tue Jun 17 04:18:14 EDT 2008
>> Hi,
>> I have a problem to connect my Postgre with R.
>> I did everything after Markus tutorial. It worked.
>> But next time I used it, I cannot go over this error:
>> "> library(Rdbi)
>> Loading required package: Rdbi
>> Error in loadNamespace(package, c(which.lib.loc, lib.loc), keep.source
= keep.source) : >   cyclic name space dependencies are not supported
>> Error : package 'Rdbi' could not be loaded
>> Error : .onLoad failed in 'loadNamespace' for 'Rdbi'
>> Error: package/namespace load failed for 'Rdbi' "
>> I also tried to reinstall R, did not help.
>> Could you help, me?
>> Best regards,
>> Stanislav >
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>>   the simpliest way it ot delete .Rdata from your home directory and
start R again
>Jarek
     When I delete "R"  folder from $HOME, all the installed packages
are deleted. This library I do have to create by installing, again and the
problem remains unsolved.
Stanislav
More information about the grass-stats
