[GRASS-stats] wrong values imported to R
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Oct 16 15:36:55 EDT 2008
upps...
I've just updated and....
> r=readRAST6("sca_mroga",plugin=TRUE)
*** caught segfault ***
address (nil), cause 'unknown'
Traceback:
1: .Call("RGDAL_OpenDataset", as.character(filename), TRUE, PACKAGE =
"rgdal")
2: .local(.Object, ...)
3: initialize(value, ...)
4: initialize(value, ...)
5: new("GDALReadOnlyDataset", filename)
6: GDAL.open(fname)
7: readGDAL(fname, silent = ignore.stderr)
8: readRAST6("sca_mroga", plugin = TRUE)
Possible actions:
1: abort (with core dump, if enabled)
2: normal R exit
3: exit R without saving workspace
4: exit R saving workspace
and I have very big problem....
Markus Neteler pisze:
> On Thu, Oct 16, 2008 at 9:02 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
>> Hi:
>> data from Grass: (integer)
>> Range of data: min = 30 max = 31589370
>> (there are more or less 14000 categories ranges as above)
>> imported to R:
>> summary(r at data$sca_mroga)
>> Min. 1st Qu. Median Mean 3rd Qu. Max.
>> -32770.0 60.0 150.0 532.1 330.0 32760.0
>> I think the problems lies in 16bit proxy .bin file during export, and we
>> have overflow
> Jarek,
> if your GRASS-R interface isn't too old, please try
> to add plugin=TRUE as parameter.
> It should enable the new method of reading in data.
> Please report if it (not) works.
> Best,
> Markus
More information about the grass-stats
