[GRASS-stats] spgrass problem importing category 999 when plugin
is FALSE
Markus Neteler
neteler at osgeo.org
Fri Apr 3 02:59:17 EDT 2009
Here my tests which look ok:
GRASS 6.5.svn (portugal):> echo "test_map=999"|r.mapcalc
100%
GRASS 6.5.svn (portugal):> R
R version 2.8.1 (2008-12-22)
> library(spgrass6)
Loading required package: sp
Loading required package: rgdal
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 1.6.0, released 2008/11/26
Path to GDAL shared files: /usr/local/share/gdal
Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
Path to PROJ.4 shared files: (autodetected)
GRASS GIS interface loaded with GRASS version: 6.5.svn
and location: portugal
> testNoPlugin=readRAST6("test_map",plugin=FALSE)
/home/neteler/grassdata/portugal/PERMANENT/.tmp/localhost/test_map has
GDAL driver GTiff
and has 1 rows and 1 columns
> summary(testNoPlugin at data)
test_map
Min. :999
1st Qu.:999
Median :999
Mean :999
3rd Qu.:999
Max. :999
> testPlugin=readRAST6("test_map",plugin=TRUE)
/home/neteler/grassdata/portugal/PERMANENT/cellhd/test_map has GDAL driver GRASS
test_map
Min. :999
1st Qu.:999
Median :999
Mean :999
3rd Qu.:999
Max. :999
Markus
2009/4/3 Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Hi
> I during batch processing of couple of maps I found strange behaviour of
> readRAST6 when I import cell map with value 999.
> Instead of 999 Na is imported (?? _
> It is for me completely strange, so I test it with folowing:
> echo "test_map=999"|r.mapclac
> R
> library(spgrass6)
> test Min. : NA 1st Qu.: NA Median : NA Mean : NaN 3rd
> Qu.: NA Max. : NA NA's :156740
> summary(testPlugin at data)
> test Min. :999 1st Qu.:999 Median :999 Mean :999 3rd Qu.:999 Max.
> :999
> It is very strange for me but I tested it on several maps. I think someone
> could try to reproduce this.
> Jarek
> BTW:
> library(spgrass6)
> Loaded GDAL runtime: GDAL 1.5.3, released 2008/09/09
> GDAL_DATA: /usr/local/lib/R/site-library/rgdal/gdal
> PROJ_LIB: /usr/local/lib/R/site-library/rgdal/proj
> and location: Rzeki
> Package: spgrass6
> Version: 0.5-16
> Date: 2008-11-13
> Built: R 2.8.1; ; 2009-01-02 14:02:31; unix
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats
