[GRASS-stats] problem with specific type of polygon
Jarek Jasiewicz jarekj at amu.edu.pl
Fri Apr 10 01:42:18 EDT 2009
Roger Bivand pisze:
> On Thu, 9 Apr 2009, Jarek Jasiewicz wrote:
>> Hi
>> it is difficult to reproduce on spearfish, because there are no data
>> like this
>> I vextorised watershed file and at the end of some watershed I have
>> sutructure like on picture below (rather tipical for watershed):
>>                          +  |                 __________|_
>>                               |_|_
>>                                  |_|_
>>                                     |_|_
>>                                        |_|
>> Addationaly every square on right-down "stream" has his own centeroid
>> but with the same cateogry like main centeroid
>> I import these data to R with readVECT6 and I have more object than
>> shoud be, because every square became a separtate vector with his own
>> attributes (some of atrributes are multipied).
>> In grass I can treat such group as one object by its category number
>> but in R? How to force R to treat these group of polygons as one obiect
> Jarek:
> An attempt is made in the code with the remove.duplicates= argument.
> In addition for polygons, you can try unionSpatialPolygons() in
> maptools to force the objects belonging together into the same
> Polygons object.
> Hope this helps,
> Roger
>> Jarek
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Yes it is it!
Thank you very much
Jarek
More information about the grass-stats mailing list
