[GRASS-stats] Raster maps from GRASS to R and back to GRASS?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Apr 11 19:53:26 EDT 2009
Nikos:
> I need a confirmation that I am doing the NA-work-around the _right_
> way.
Sorry, I fat-fingered the Send button before. For simplicity I tried to
use small names instead of the long "original" names. Anyhow, I think
it's clear what I am doing and what the problem is.
The problem is:
> I get several NULL's in the raster maps I write back in GRASS in
> locations (=pixels) were the input raster map(s) have a NON-NULL value.
For simplicity I tried to use small names instead of the long "original"
names. Anyhow, I think it's clear what I am doing and what the problem
is.
Cheers, Nikos
# launch grass; launch R from within grass
# load libraries and projection information
library(spgrass6); G <- gmeta6()
# load data
raw <- readRAST6 (c('a', 'b', 'c', 'd', 'e', 'f'))
# create vector pointing to values
values <- which(!is.na(raw at data$a) & !is.na(raw at data$b) & !
is.na(raw at data$c) & !is.na(raw at data$d) & !is.na(raw at data$e) & !
is.na(raw at data$f))
# get data
data <- raw at data[values, ]
# check structure
str(data)
# perform pca with prcomp(): SVD - SCALED
prcomp.data <- prcomp(data, scale=TRUE)
prcomp.data$rotation
summary(prcomp.data)
# add new columns to the original sp object #
raw at data$pc1 <- NA
raw at data$pc2 <- NA
raw at data$pc3 <- NA
raw at data$pc4 <- NA
raw at data$pc5 <- NA
raw at data$pc6 <- NA
str(raw)
# fill-in the PCs
raw at data$pc1[values] <- prcomp.data$x[,"PC1"]
raw at data$pc2[values] <- prcomp.data$x[,"PC1"]
raw at data$pc3[values] <- prcomp.data$x[,"PC1"]
raw at data$pc4[values] <- prcomp.data$x[,"PC1"]
raw at data$pc5[values] <- prcomp.data$x[,"PC1"]
raw at data$pc6[values] <- prcomp.data$x[,"PC1"]
# write grass raster maps
writeRAST6(raw, zcol=7, vname="prcomp1_0607", overwrite=TRUE)
writeRAST6(raw, zcol=8, vname="prcomp1_0607", overwrite=TRUE)
writeRAST6(raw, zcol=9, vname="prcomp1_0607", overwrite=TRUE)
writeRAST6(raw, zcol=10, vname="prcomp1_0607", overwrite=TRUE)
writeRAST6(raw, zcol=11, vname="prcomp1_0607", overwrite=TRUE)
writeRAST6(raw, zcol=12, vname="prcomp1_0607", overwrite=TRUE)
More information about the grass-stats
