[GRASS-stats] Re: spgrass6 and initGRASS
Roger Bivand
Roger.Bivand at nhh.no
Tue Dec 8 04:57:57 EST 2009
On Tue, 8 Dec 2009, Patrick Giraudoux wrote:
> Roger Bivand a écrit :
>> On Mon, 7 Dec 2009, Roger Bivand wrote:
>>> On Mon, 7 Dec 2009, Patrick Giraudoux wrote:
>>>> Dear Roger,
>>>> I have moved the thread and the answer below from
>>>> qgis-user at lists.osgeo.org to this list as advised...
>>>>> That is because the GRASS environment variables have not been set at
>>>>> that point. Do you need to use GRASS in throw-away (initGRASS) mode, or
>>>>> with an existing location? If the latter, please use the interface in
>>>>> the regular way, starting R "within" GRASS. I'll try to reproduce the
>>>>> problem, but it is not easy to do, I'm afraid.
>>> Dear Patrick,
>>> I've tried with Metis with no success. The first problem is addressed in
>>> this draft release:
>>> http://spatial.nhh.no/R/Devel/spgrass6_0.6-13.zip
>>> but with Metis is simply falls over later. With WinGRASS (last but
>>> latest), it just works. It even works in Metis once the basic GRASS
>>> framework is set up using WinGRASS, but behaviour is erratic and
>>> unpredictable. To track it with Metis (which I just uninstalled to try
>>> OSGeo4W) seemed impossible, it wasn't clear where the GRASS modules were
>>> looking for their environment variables and GISRC backstore.
>>> I would probably use file transfer and have QGIS do the desktop mapping
>>> and WinGRASS the analytical stuff, but I can't say that I have favourites
>>> here.
>> I've now installed QGIS 1.3.0 Mimas and GRASS 6.4.0 SVN from OSGeo4W. Doing
>> it their way (rather than my way), you then need Carson Farmer's ManageR
>> plugin and the rpy2 2.0.6 msi for python 2.5 (the one that OSGeo4W ships).
>> Next probably you need to put your R (mine is 2.10.0) on the PATH which
>> OSGeo4W and QGIS have manipulated - maybe through the control panel - needs
>> updating manually.
>> Start QGIS, look for Carson's repository, install and enable manageR, open
>> a GRASS mapset in QGIS, enter library(spgrass6) in the manageR console, and
>> if you're lucky GRASS may be there. I've managed to move spearfish roads to
>> R and tabulate road length by class using SpatialLinesLength() on the
>> representation on the R side. Fairly horrible to install for students, but
>> maybe?
>> Roger
> Yes indeed. That was a concern to me. The previous standalone versions of
> QGIS metis was good enough and R could simply be started from within a GRASS
> session (console) in QGIS... and the OSGEO4W SVN Kore and Mimas were the
> same. I am using R 2.10.0 too. Except that in all versions any error in R led
> to quit and come back to the GRASS console... I have already exported R
> objects (eg "gmeta6" files) that way. On the other hand, GRASS commands were
> quite OK to manage with the console (but no copy and paste function
> available...).
> My hope with initGRASS was just to avoid opening a GRASS session and to read
> files from R with gmeta6, and maybe readRAST6, readVECT6 without having to
> start/working with GRASS or QGIS.... Looks like being out of reach yet with
> QGIS/GRASS under Windows.
With QGIS/GRASS under Windows yes, but with WinGRASS native it works fine
for me - no need to start GRASS, and the vast majority of GRASS commands
avaliable from execGRASS. See maybe:
http://spatial.nhh.no/R/Devel/WinGRASS_initGRASS.swf
using
http://spatial.nhh.no/R/Devel/spgrass6_0.6-14.zip
that is using WinGRASS without starting GRASS on an existing location and
mapset.
Hope this helps,
Roger
> Anyway thanks for having had a look and for all the work done with spgrass6
> (and others !)
> Best,
> Patrick
>>>> I would like to be capable to read into GRASS locations from within R (so
>>>> not from R started withing GRASS) -what is supposedly done with
>>>> initGRASS; eg just to pick up a region definition into a "spgrass6"
>>>> object and compute on that. I though that initGRASS was design for this
>>>> task.
>>> Right, initGRASS with home=tempdir() (not what I replied earlier - with no
>>> home= given, it uses whatever Windows says "HOME" is) starts a new
>>> location and mapset in the R temporary directory, which you move data to
>>> for GRASS to analyse.
>>>>> Have you tried the WinGRASS stand-alone (I haven't trusted either QGIS
>>>>> GRASS used this way or OSGeo4W - I follow the bug-tracker for OSGEO4W,
>>>>> so stay away)?
>>>> I am trying this essentially on teaching purposes. Students are working
>>>> under Windows XP and Vista. I have only a limited number of hours, and to
>>>> board GIS concepts from QGIS then to GRASS is somehow easier for them
>>>> than straight within GRASS (although it is just the reverse when you know
>>>> GRASS). The QGIS Metis standalone version was excellent for that. You
>>>> have seen that the updates to Kore and Mimas are done with no standalone
>>>> version available on the QGIS official site. There the use of OSGeo4W is
>>>> encouraged and I am trying to find out what could be best advisable for
>>>> the students.
>>>> I did not tried WinGRASS yet, and I am interested in doing it, but have
>>>> installed the OSGeo4W GRASS 6.4svn version (works well - but definitely
>>>> the unix/linux environment is more convenient for command lines), as well
>>>> as OSGeo4W QGIS Kore and Mimas, and try and compare them.
>>> Roger
>>>>> What is your sessionInfo()?
>>>> sessionInfo()
>>>> R version 2.10.0 (2009-10-26)
>>>> i386-pc-mingw32
>>>> locale:
>>>> [1] LC_COLLATE=French_France.1252 LC_CTYPE=French_France.1252 [3]
>>>> LC_MONETARY=French_France.1252 LC_NUMERIC=C [5]
>>>> LC_TIME=French_France.1252 attached base packages:
>>>> [1] grDevices datasets splines graphics stats tcltk utils
>>>> [8] methods base other attached packages:
>>>> [1] spgrass6_0.6-12 XML_2.6-0 rgdal_0.6-22 sp_0.9-47 [5]
>>>> svSocket_0.9-48 TinnR_1.0.3 R2HTML_1.59-1 Hmisc_3.7-0 [9]
>>>> survival_2.35-7
>>>> loaded via a namespace (and not attached):
>>>> [1] cluster_1.12.1 grid_2.10.0 lattice_0.17-26 svMisc_0.9-56 [5]
>>>>>> Have tried the following:
>>>>>> initGRASS("C:\\OSGeo4W\\bin",home="U:\\Documents and
>>>>>> Settings\\pgiraudo\\",override=T)
>>>>>> initGRASS("C:\\Program Files\\Quantum GIS\\grass",home="U:\\Documents
>>>>>> and Settings\\pgiraudo",override=T)
>>>>>> initGRASS("C:\\OSGeo4W\\bin",override=T)
>>>>>> with the same results...
>>>>>> Error in system(paste("g.dirseps.exe -g",
>>>>>> shQuote(Sys.getenv("WINGISRC"))), :
>>>>>> g.dirseps.exe not found
>>>>>>> and
>>>>>> Error in Sys.setenv(GISRC = gisrc) : wrong length for argument
>>>>>> Quite puzzling since g.dirseps does not give a message "unknown
>>>>>> command" when tried within grass (thus it is suppose to be in the GRASS
>>>>>> programme)
>>>>> What is your sessionInfo()? Have you tried the WinGRASS stand-alone (I
>>>>> haven't trusted either QGIS GRASS used this way or OSGeo4W - I follow
>>>>> the bug-tracker for OSGEO4W, so stay away)?
>>>>> Would you mind moving to the proper list - this is a GRASS question much
>>>>> more than an R one:
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>>>>> Roger
>>>>>> Patrick
>>>>>>>> Here is the result:
>>>>>>>> library(spgrass6)
>>>>>>>> debug(initGRASS)
>>>>>>>>> initGRASS("C:/OSGeo4W/bin",home="U:/Documents and
>>>>>>>> Settings/pgiraudo/",override=T)
>>>>>>>> Browse[2]>
>>>>>>>> debug: gisrc <- system(paste("g.dirseps.exe -g",
>>>>>>>> intern = TRUE)
>>>>>>>> Browse[2]> Sys.getenv("WINGISRC")
>>>>>>>> WINGISRC
>>>>>>>> "U:/Documents and Settings/pgiraudo/\\.grassrc6"
>>>>>>>> Browse[2]> shQuote(Sys.getenv("WINGISRC"))
>>>>>>>> [1] "\"U:/Documents and Settings/pgiraudo/\\.grassrc6\""
>>>>>>>> Browse[2]> gisrc
>>>>>>>> Error: object 'gisrc' not found
>>>>>>> Could you try both not setting home= (you get a temporary folder that
>>>>>>> is deleted when you exit R), or setting
>>>>>>> home="U:\\Documents and Settings\\pgiraudo"
>>>>>>> without the trailing forward slash?
>>>>>>> This a problem connected to protecting spaces on the one hand and
>>>>>>> system specific directory separators on the other, I think.
>>>>>>> Roger
>>>>>>>> Beforehand, the first time I run
>>>>>>>> Settings/pgiraudo/",override=T), I got:
>>>>>>>> Then, if I try the same commande on QGIS Metis, I got:
>>>>>>>> initGRASS("C:/Program Files/Quantum GIS/grass",home="U:/Documents and
>>>>>>>> Settings/pgiraudo",override=T)
>>>>>>>> Best,
>>>>>>>> Patrick
>>>>>>>>> On Sun, 6 Dec 2009, Patrick Giraudoux wrote:
>>>>>>>>>> Dear all,
>>>>>>>>>> I am trying to init a GRASS session from within R, using the
>>>>>>>>>> function initGRASS from the package spgrass6. GRASS is installed in
>>>>>>>>>> two ways on my computer (here, the OS is Windows XP): with QGIS
>>>>>>>>>> metis (precompiled version including grass 6.3 (2008)) and grass
>>>>>>>>>> 6.4.0svn, just freshly installed with the Osgeo4W installer.
>>>>>>>>>> In both cases I get the same result:
>>>>>>>>>>> and
>>>>>>>>>> Any idea about what happens ?
>>>>>>>>> No, without the output of traceback(), it isn't obvious, although
>>>>>>>>> here traceback() might not help. Run under debug(initGRASS) to the
>>>>>>>>> step before, that is:
>>>>>>>>> shQuote(Sys.getenv("WINGISRC"))), intern=TRUE)
>>>>>>>>> then run:
>>>>>>>>> gisrc
>>>>>>>>> and try to see what is going on. At this stage, Sys.getenv("GISRC")
>>>>>>>>> should be "junk", assigned a couple of lines earlier.
>>>>>>>>> Maybe the grass-stats list would have a higher proportion of users
>>>>>>>>> of both GRASS and R.
>>>>>>>>> Hope this helps,
>>>>>>>>> Roger
>>>>>>>>>> Patrick
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
