[GRASS-stats] error rgdal library if used from within Grass plugin
(Windows)
Agustin Lobo
aloboaleu at gmail.com
Mon Feb 9 09:07:14 EST 2009
Hi!
The following error only occurs if the R (2.7.2) session is started
from a GRASS shell opened through the QGIS GRASS plugin in windows.
The error does not occur If R is started form its own icon
or by double click in the .RData object, but then the spgrass6
package would not find the GRASS environment.
It also works in linux.
The involved commands are:
1. Start QGIS
2. Star GRASS plugin and open mapset
3. Open Grass Shell
4. Run R and execute require(spgrass6)
>>>> Loading required package: spgrass6
>>>> Loading required package: rgdal
>>>> Error in fun(...) :
>>>> GDAL Error 1: Can't load requested DLL:
>>>> C:\OSGeo4W\bin\gdalplugins\gdal_ECW_JP2ECW.dll
>>>> 126: Não foi possível encontrar o módulo especificado.
>>>> Error : .onLoad failed in 'loadNamespace' for 'rgdal'
>>>> Erro: package 'rgdal' could not be loaded
Any help appreciated.
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
More information about the grass-stats
