[GRASS-stats] How to calculate the Bhattacharyya distance/index?
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Feb 14 08:27:41 EST 2009
Agus,
I really appreciate your kind support. It's important to have some hand
to push you a bit when you are stuck :-) I am convinced that you know
that better than many other people.
The problem is that I must use it wrong. I have 42 samples (number of
pixel varies and is not really too big) extracted from:
(1) a 3x3 matrix with columns MODIS prefire.band2, prefire.band 6 and
prefire.band7
(2) a 3x3 matrix with columns MODIS postfire.band2, postfire.band 6 and
postfire.band 7
When I feed these two as PRE and POST in my function JM <-
function(PRE,POST) etc., I get a Bhattacharayya distance of -50.xxx and
the JM becomes something like -7.xxx
As you might have noticed I use colMeans() to calculate each bands mean.
I really am stuck and can't seem to understand what I am doing wrong. Is
it really that difficult? :-0
Thank you in advance, of course even if you don't have the time to
reply. Nikos
More information about the grass-stats
