[GRASS-stats] Incompatible library version for module SOLVED
but new problem with plugin=TRUE has emerged
Roger Bivand
Roger.Bivand at nhh.no
Sun Jan 11 10:48:19 EST 2009
On Sat, 10 Jan 2009, Markus Neteler wrote:
> Roger,
> On Sat, Jan 10, 2009 at 9:20 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> On Sat, Jan 3, 2009 at 11:09 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>> The current settings of readRAST6() will use the plugin if available (but
>>>> try to check that the regions match) when plugin=NULL. If you want to
>>>> force
>>>> the use of r.out.gdal, set plugin=FALSE and useGDAL=TRUE (version
>>>> 0.5-16).
>>>> Please let me know if this helps.
>>> I have installed R (R version 2.8.1 (2008-12-22)) + extensions from
>>> scratch.
>>> I get now this message (GRASS book p. 358):
>>>> elev <- readRAST6("elev_state_500m", mapset="PERMANENT",
>>>> ignore.stderr=TRUE)
>>> cols rows origin.northing origin.easting
>>> FALSE FALSE FALSE TRUE
>>> Warning message:
>>> In readRAST6("elev_state_500m", mapset = "PERMANENT", :
>>> set plugin=FALSE - raster/current window mismatch
>>> or plugin=TRUE to override; continuing with plugin=FALSE
>>> To me it is not clear from the message that I should (better) set
>>> useGDAL=TRUE
>>> Ideally, the interface would work as simple as this
>>> elev <- readRAST6("elev_state_500m")
>>> which would
>>> * find the map in the current mapset search path (internally, use
>>> g.findfile),
>>> in my tests I was in a mapset different from PERMANENT which leads to
>>> elev <- readRAST6("elev_state_500m", ignore.stderr=TRUE)
>>> Error in .local(.Object, ...) :
>>> GDAL Error 4:
>>> `/home/neteler/grassdata/nc_spm_07/user1/cellhd/elev_state_500m' does
>>> not exist in the file system,
>>> and is not recognised as a supported dataset name.
>>> * use the current region (internally, use r.in.gdal and not the plugin
>>> if GRASS >= 6.4)
>> Markus,
>> This is effectively what I've tried to now. However, the user output is:
>>> library(spgrass6)
>> Loading required package: sp
>> Loading required package: rgdal
>> Geospatial Data Abstraction Library extensions to R successfully loaded
>> Loaded GDAL runtime: GDAL 1.6.0, released 2008/12/04
>> GDAL_DATA: /home/rsb/lib/r_libs/rgdal/gdal
>> Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
>> PROJ_LIB: /home/rsb/lib/r_libs/rgdal/proj
>> GRASS GIS interface loaded with GRASS version: 6.4.0RC1
>> and location: nc_spm_08
>> FALSE FALSE FALSE FALSE
>> ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in TIFF
>> format.
> This message *is* confusing as it is a warning only. It comes from GDAL:
> gdal/frmts/gtiff/geotiff.cpp: "SetColorTable() only
> supportedfor Byte or UInt16 bands in TIFF format." );
> if( eDataType != GDT_Byte && eDataType != GDT_UInt16 )
> CPLError( CE_Failure, CPLE_NotSupported,
> "SetColorTable() only supported for Byte or UInt16
> return CE_Failure;
> I suppose there is some trick to suppress it (since it uses the
> CPLError function).
> I don't know too much about it but found
> http://www.gdal.org/ogr/cpl__error_8h.html#ad2b98dd58e4de706a245faddac90403
> Just throw stderr stuff to /dev/null (of course problematic with Windows)?
I've "handled" this for some definition of handle by setting -c in the
r.out.gdal call - this was controlling whether colour table writing was
attempted.
>> WARNING: Input raster map contains cells with NULL-value (no-data). The
>> value 999 was used to represent no-data values in the input map.
>> You can specify nodata value by nodata parameter.
> That one comes from r.out.gdal. Indeed a non-feature, see below:
>> /home/rsb/topics/grassdata/nc_spm_08/rsb/.tmp/reclus2/elev_state_500m has
>> GDAL driver GTiff
>> and has 620 rows and 1630 columns
>> Warning message:
>> In readRAST6("elev_state_500m") :
>> which I agree is unhelpful (and most of it cannot be avoided on Windows,
>> where stderr cannot be ignored). I can work on some of this, but the two
>> r.out.gdal messages are not on my side. Even if I set GRASS_VERBOSE to 0,
>> won't they still be displayed?
> It was implemented as G_warning(). In contact with the person who
> added this, we have now changed to G_important_message() which
> respects GRASS_VERBOSE=0:
> http://trac.osgeo.org/grass/changeset/35321
> It is in 6.4SVN and 7 SVN and will appear on Monday in 6.4.0RC2.
> GRASS 6.3 and older are not affected as r.out.gdal wasn't there.
With 6.4SVN I now get:
> library(spgrass6)
GRASS GIS interface loaded with GRASS version: 6.4.0svn
raster/current region mismatch detected in components:
set plugin=TRUE to override; continuing with plugin=FALSE
GDAL driver GTiff
I've committed to sourceforge CVS, could you confirm that this is OK?
How does one manage the plugin links in a mixed 6.4/7.0 setting? I tried
7.0 first, but I think there was a problem:
ERROR: Incompatible library version for module
which crashed R/rgdal. The plugin was built against 6.4RC1, so probably
two different library versions had a disagreement.
Best wishes,
Roger
> Thanks,
> Markus
>> Roger
>>> Successfully, I have used today:
>>> ignore.stderr=TRUE, plugin=FALSE, useGDAL=TRUE)
>>> which is rather long/complex.
>>> Hope I am not asking too much - try to compensate with GRASS 6.4.x work :)
>>> Markus
>> Roger Bivand
>> Economic Geography Section, Department of Economics, Norwegian School of
>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>> e-mail: Roger.Bivand at nhh.no
Roger Bivand
More information about the grass-stats
