[GRASS-stats] Incompatible library version for module SOLVED but
new problem with plugin=TRUE has emerged
Markus Neteler
neteler at osgeo.org
Sun Jan 11 14:01:27 EST 2009
On Sun, Jan 11, 2009 at 7:09 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Jan 11, 2009 at 4:48 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> On Sat, 10 Jan 2009, Markus Neteler wrote:
>>> On Sat, Jan 10, 2009 at 9:20 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>>>> On Sat, Jan 3, 2009 at 11:09 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> I'll do (tonight I won't manage and I got the mail only now due to
> osgeo mail reflector stuck for some hours).
> Hope tomorrow morning as first thing.
I managed to test and it went through well.
>> How does one manage the plugin links in a mixed 6.4/7.0 setting? I tried 7.0
>> first, but I think there was a problem:
>> ERROR: Incompatible library version for module
>> which crashed R/rgdal. The plugin was built against 6.4RC1, so probably two
>> different library versions had a disagreement.
> Oh, this is really a problem and needs to be discussed on grass-dev
> or via trac ticket. Glynn had added this test which will cause troubles
> here. Maybe there is a workaround possible.
This remains open yet.
Thanks again,
Markus
More information about the grass-stats
