[GRASS-stats] Incompatible library version for module SOLVED
but new problem with plugin=TRUE has emerged
Roger Bivand
Roger.Bivand at nhh.no
Tue Jan 13 03:23:07 EST 2009
The changes to handle finding files in other mapsets and to remove
confusing messages have been included in spgrass6_0.5-17, now released on
CRAN. It checks cleanly against 6.4.0svn, Revision: 35395, so RC2 is good
too (this is the svn up number, but the number in Help -> "About GRASS
GIS" in the wxpython GUI is lower - any way to harmonise?).
Roger
On Sun, 11 Jan 2009, Roger Bivand wrote:
> On Sun, 11 Jan 2009, Markus Neteler wrote:
>> On Sun, Jan 11, 2009 at 4:48 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> On Sat, 10 Jan 2009, Markus Neteler wrote:
>>>> On Sat, Jan 10, 2009 at 9:20 PM, Roger Bivand <Roger.Bivand at nhh.no>
>>>>>> On Sat, Jan 3, 2009 at 11:09 AM, Roger Bivand <Roger.Bivand at nhh.no>
>>>>>> wrote:
>>>> This message *is* confusing as it is a warning only. It comes from GDAL:
>>>> gdal/frmts/gtiff/geotiff.cpp: "SetColorTable() only
>>>> supportedfor Byte or UInt16 bands in TIFF format." );
>>>> if( eDataType != GDT_Byte && eDataType != GDT_UInt16 )
>>>> CPLError( CE_Failure, CPLE_NotSupported,
>>>> "SetColorTable() only supported for Byte or UInt16
>>>> return CE_Failure;
>>>> I suppose there is some trick to suppress it (since it uses the
>>>> CPLError function).
>>>> I don't know too much about it but found
>>>> http://www.gdal.org/ogr/cpl__error_8h.html#ad2b98dd58e4de706a245faddac90403
>>>> Just throw stderr stuff to /dev/null (of course problematic with
>>>> Windows)?
>>> I've "handled" this for some definition of handle by setting -c in the
>>> r.out.gdal call - this was controlling whether colour table writing was
>>> attempted.
>> ah fine, I didn't think of this possibility.
>>>>> WARNING: Input raster map contains cells with NULL-value (no-data). The
>>>>> value 999 was used to represent no-data values in the input map.
>>>>> You can specify nodata value by nodata parameter.
>>>> http://trac.osgeo.org/grass/changeset/35321
>>>> It is in 6.4SVN and 7 SVN and will appear on Monday in 6.4.0RC2.
>>>> GRASS 6.3 and older are not affected as r.out.gdal wasn't there.
>>> With 6.4SVN I now get:
>>>> library(spgrass6)
>>> Loading required package: sp
>>> Loading required package: rgdal
>>> Geospatial Data Abstraction Library extensions to R successfully loaded
>>> Loaded GDAL runtime: GDAL 1.6.0, released 2008/12/04
>>> GDAL_DATA: /home/rsb/lib/r_libs/rgdal/gdal
>>> Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
>>> PROJ_LIB: /home/rsb/lib/r_libs/rgdal/proj
>>> GRASS GIS interface loaded with GRASS version: 6.4.0svn
>>> and location: nc_spm_08
>>>> elev <- readRAST6("elev_state_500m")
>>> raster/current region mismatch detected in components:
>> may I suggest cosmetics:
>> raster map/current region mismatch detected in components:
> Committed - so you'll see this when you get to it, thanks.
> I'll worry about the 6.4 - 7.0 plugin issue when it becomes more pressing for
> me - for now I'll avoid 7.0.
> Best wishes,
> Roger
>>> cols rows origin.northing origin.easting
>>> FALSE FALSE FALSE FALSE
>>> set plugin=TRUE to override; continuing with plugin=FALSE
>>> /home/rsb/topics/grassdata/nc_spm_08/rsb/.tmp/reclus2/elev_state_500m has
>>> GDAL driver GTiff
>>> and has 620 rows and 1630 columns
>>>> elev <- readRAST6("elev_state_500m", ignore.stderr=TRUE)
>>> I've committed to sourceforge CVS, could you confirm that this is OK?
>> I'll do (tonight I won't manage and I got the mail only now due to
>> osgeo mail reflector stuck for some hours).
>> Hope tomorrow morning as first thing.
>>> How does one manage the plugin links in a mixed 6.4/7.0 setting? I tried
>>> 7.0
>>> first, but I think there was a problem:
>>> ERROR: Incompatible library version for module
>>> which crashed R/rgdal. The plugin was built against 6.4RC1, so probably
>>> two
>>> different library versions had a disagreement.
>> Oh, this is really a problem and needs to be discussed on grass-dev
>> or via trac ticket. Glynn had added this test which will cause troubles
>> here. Maybe there is a workaround possible.
>> Thanks for your efforts.
>> Best wishes,
>> Markus
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
