[GRASS-stats] [Report #6] Kriging with GRASS and R: v.autokrige
port to wxPython and more
Anne Ghisla
a.ghisla at gmail.com
Fri Jul 3 08:51:56 EDT 2009
Hello all, and sorry for cross-posting,
this week I worked on removing parameters hardwired in the code, binding
them to the interface instead.
Therefore, now it is possible use all widgets in gstat and automap
pages, i.e. pick up the model from a list, set sill, nugget and range;
set the output raster map name and eventually overwrite it.
I'm going to implement CLI in these next days, it will very likely need
to reorganise the code and clearly split interface from model.
Blocking issues - none.
best regards,
Anne
More info on the wiki page - updated daily:
http://grass.osgeo.org/wiki/V.autokrige_GSoC_2009
Name: not available
Desc: Questa =?ISO-8859-1?Q?=E8?= una parte del messaggio
firmata digitalmente
Url : http://lists.osgeo.org/pipermail/grass-stats/attachments/20090703/96696fb4/attachment.bin
More information about the grass-stats
