[GRASS-stats] Re: [GRASS-user] error: Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations.
Wed Jul 29 06:23:33 EDT 2009
Nikos Alexandris wrote:
> Hi dev's and advanced useRs,
> I have seen this message for the X-th time now :-( while trying to load
> (anything) data using readRAST6 or readVECT6.
> I've rebuild grass-6.4.0svn 2-3 times now. I've re-installed R 2-3 times
> as well. Not to mention how many attempts to get "spgrass6".
> Which is the "incompatible library"
libgrass_gis
> and to which "module" does it refer to?
Whatever is calling G_gisinit().
> Is this an R error or a grass error? Any help is *higly*
> appreciated.
It means that something was compiled using <grass/gis.h> from one
version of GRASS, but when run it uses libgrass_gis from a different
version.
It may be a problem with R. It can also be caused by a GDAL library
(or GDAL-GRASS plugin) which was built with GRASS support. You might
want to try using gdalinfo on a GRASS dataset to confirm or deny this
possibility.
More information about the grass-stats mailing list
