[GRASS-stats] another gstat error
Edzer Pebesma
edzer.pebesma at uni-muenster.de
Mon Jun 22 04:04:58 EDT 2009
Jarek Jasiewicz wrote:
> Roger Bivand pisze:
>> So it looks as though you may have points that are seen as identical
>> in your data set.
>> Hope this helps,
>> Roger
> Yes, it is possible, I must find method to identyfy and remove
> duplicates I will try SPATSTAT's remove duplicate functions
package sp has function zerodist for this purpose.
Edzer
> Thanks an many
> Jarek
>>>> Including a drift in untransformed coordinates is very likely to
>>>> lead to numerical chaos. If z~1 works, then the smoking gun is the
>>>> x+y, isn't it? If you want them, transform them (offset with for
>>>> example elide() in maptools and transform back afterwards).
>>>> Roger
>>>>> I can't imagine the reason
>>>>> regards
>>>>> Jarek
>>>>> here is structure of my gr spatialPointsDataFrame used in analysis:
>>>>> str(gr)
>>>>> Formal class 'SpatialPointsDataFrame' [package "sp"] with 5 slots
>>>>> ..@ data :'data.frame': 2201 obs. of 5 variables:
>>>>> .. ..$ cat: num [1:2201] 2 3 4 5 6 7 8 9 10 11 ...
>>>>> .. ..$ naz: Factor w/ 874 levels "1000","1001",..: 874 1 2 3 4 5 6
>>>>> 7 8 9 ...
>>>>> .. ..$ x : num [1:2201] 360175 360176 360178 360169 360167 ...
>>>>> .. ..$ y : num [1:2201] 512736 512736 512733 512719 512712 ...
>>>>> .. ..$ z : num [1:2201] 86.5 87.4 87.7 86.9 86 ...
>>>>> ..@ coords.nrs : num(0)
>>>>> ..@ coords : num [1:2201, 1:2] 360175 360176 360178 360169
>>>>> 360167 ...
>>>>> .. ..- attr(*, "dimnames")=List of 2
>>>>> .. .. ..$ : NULL
>>>>> .. .. ..$ : chr [1:2] "coords.x1" "coords.x2"
>>>>> ..@ bbox : num [1:2, 1:2] 359907 512481 360492 512778
>>>>> .. .. ..$ : chr [1:2] "min" "max"
>>>>> ..@ proj4string:Formal class 'CRS' [package "sp"] with 1 slots
>>>>> .. .. ..@ projargs: chr " +proj=tmerc +lat_0=0 +lon_0=19 +k=0.9993
>>>>> +x_0=500000 +y_0=-5300000 +no_defs +a=6378137 +rf=298.257222101
>>>>> +towgs84=0.000,0.000,"| __truncated__
>>>>> and newdata grid:
>>>>> str(grid)
>>>>> Formal class 'SpatialGridDataFrame' [package "sp"] with 6 slots
>>>>> ..@ data :'data.frame': 131352 obs. of 1 variable:
>>>>> .. ..$ region2: int [1:131352] NA NA NA NA NA NA NA NA NA NA ...
>>>>> ..@ grid :Formal class 'GridTopology' [package "sp"] with 3
>>>>> slots
>>>>> .. .. ..@ cellcentre.offset: Named num [1:2] 359902 512478
>>>>> .. .. .. ..- attr(*, "names")= chr [1:2] "x" "y"
>>>>> .. .. ..@ cellsize : num [1:2] 1.001 0.998
>>>>> .. .. ..@ cells.dim : int [1:2] 421 312
>>>>> ..@ grid.index : int(0)
>>>>> ..@ coords : num [1:2, 1:2] 359902 360322 512478 512788
>>>>> .. .. ..$ : NULL
>>>>> .. .. ..$ : chr [1:2] "x" "y"
>>>>> ..@ bbox : num [1:2, 1:2] 359901 512477 360323 512789
>>>>> _______________________________________________
>>>>> grass-stats mailing list
>>>>> grass-stats at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Edzer Pebesma
Institute for Geoinformatics (ifgi), University of Münster
Weseler Straße 253, 48151 Münster, Germany. Phone: +49 251
8333081, Fax: +49 251 8339763 http://ifgi.uni-muenster.de/
http://www.springer.com/978-0-387-78170-9 e.pebesma at wwu.de
More information about the grass-stats
