[GRASS-stats] universal kriging with spgrass6
Edzer Pebesma
edzer.pebesma at uni-muenster.de
Thu Jun 25 17:18:43 EDT 2009
Mathieu, that could very well be the case. Note that x+y do not
"generally" refer to x- and y-coordinates, but are the actual names of
the coordinates (or something else). From your example I cannot find out
whether the coordinates are named x and y. In addition, they should have
identical names in sitesR and mask_SG.
Best regards,
Edzer
mathieu grelier wrote:
Dear all,
I am trying to achieve universal kriging with GRASS and R through spgrass6
package.
Maybe you could help me to find the right R syntax.
As in the gstat doc, the polynomial I try to use for now is "x+y"
> Dear all,
> package.
> In R, with automap package, this works :
>> data(meuse)
>> coordinates(meuse) = ~x+y
>> data(meuse.grid)
>> gridded(meuse.grid) = ~x+y
>> column = "zinc"
> ##Ordinary kriging :
>> predictors = "1"
>> autoKrige(as.formula(paste(column,"~", predictors)), meuse, meuse.grid)
> ##Universal kriging :
>> predictors = "x+y"
> But using spgrass6, it becomes (some steps have been skipped):
>> sitesR <- readVECT6("grass_sites")
>> mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
> ##Ordinary kriging => WORKS:
>> predictors = "1"
>> kriging_result = autoKrige(as.formula(paste(column,"~",predictors)),
> sitesR, mask_SG)
> ##Universal kriging => ERROR:
>> predictors = "x+y"
> sitesR, mask_SG)
>> Error in eval(expr, envir, enclos) : "x" object not found
> Why can't we use the x an y columns here?
> Maybe it is because the meuse and sites R data.frames don't have the same
> structure ?
>> class(meuse)
> [1] "data.frame"
>> attributes(meuse)
> $names
> [1] "x" "y" "cadmium" "copper" "lead" "zinc" "elev"
>> class(sitesR)
> [1] "SpatialPointsDataFrame"
>> attributes(sitesR)
> $bbox
> $proj4string
> $coords
> $data
> site value cat x y
> 1Ai 81.80 1 825094.9 6796083
> 2 Al 38.50 2 758780.4 6851508
> 3 Ar 103.50 3 818973.3 6796125
> 4 Av 52.50 4 775136.0 6877271
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Edzer Pebesma
Institute for Geoinformatics (ifgi), University of Münster
Weseler Straße 253, 48151 Münster, Germany. Phone: +49 251
8333081, Fax: +49 251 8339763 http://ifgi.uni-muenster.de/
http://www.springer.com/978-0-387-78170-9 e.pebesma at wwu.de
More information about the grass-stats
