[GRASS-stats] universal kriging with spgrass6
Edzer Pebesma edzer.pebesma at uni-muenster.de
Fri Jun 26 02:43:21 EDT 2009
Roger Bivand wrote:
> On Thu, 25 Jun 2009, Edzer Pebesma wrote:
>> Mathieu, that could very well be the case. Note that x+y do not
>> "generally" refer to x- and y-coordinates, but are the actual names of
>> the coordinates (or something else). From your example I cannot find out
>> whether the coordinates are named x and y. In addition, they should have
>> identical names in sitesR and mask_SG.
> Yes, it is beginning to look like the names in mask_SG, isn't it? Do
> you have a view on whether degree= should be mandatory, or does the
> infrastructure recognise coordinate RHS variables and rescale them
> automatically (I doubt the latter)? Why do users use trend variables
> in this way - the range of values in the (X'X) matrix becomes enormous
> with the usual metre metric for coordinates?
Another question we could ask (ourselves) is why in R we allow users to
give their coordinates the names they like. I remember that for that
sole reason (need to rename) I added the function
coordnames(x) = c("u", "v")
to sp. In case they're called "lon" and "lat", they also don't change
name after projection. But maybe I talk too much with people worrying
about semantics, these days. ;-)
Edzer
> Roger
>> Best regards,
>> Edzer
>> mathieu grelier wrote:
>> Dear all,
>> I am trying to achieve universal kriging with GRASS and R through
>> spgrass6
>> package.
>> Maybe you could help me to find the right R syntax.
>> As in the gstat doc, the polynomial I try to use for now is "x+y"
>>> Dear all,
>>> spgrass6
>>> package.
>>> In R, with automap package, this works :
>>>> data(meuse)
>>>> coordinates(meuse) = ~x+y
>>>> data(meuse.grid)
>>>> gridded(meuse.grid) = ~x+y
>>>> column = "zinc"
>>> ##Ordinary kriging :
>>>> predictors = "1"
>>>> autoKrige(as.formula(paste(column,"~", predictors)), meuse,
>>>> meuse.grid)
>>> ##Universal kriging :
>>>> predictors = "x+y"
>>>> meuse.grid)
>>> But using spgrass6, it becomes (some steps have been skipped):
>>>> sitesR <- readVECT6("grass_sites")
>>>> mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
>>> ##Ordinary kriging => WORKS:
>>>> predictors = "1"
>>>> kriging_result = autoKrige(as.formula(paste(column,"~",predictors)),
>>> sitesR, mask_SG)
>>> ##Universal kriging => ERROR:
>>>> predictors = "x+y"
>>> sitesR, mask_SG)
>>>> Error in eval(expr, envir, enclos) : "x" object not found
>>> Why can't we use the x an y columns here?
>>> Maybe it is because the meuse and sites R data.frames don't have the
>>> same
>>> structure ?
>>>> class(meuse)
>>> [1] "data.frame"
>>>> attributes(meuse)
>>> $names
>>>  [1] "x"       "y"       "cadmium" "copper"  "lead"    "zinc"    "elev"
>>>> class(sitesR)
>>> [1] "SpatialPointsDataFrame"
>>>> attributes(sitesR)
>>> $bbox
>>> $proj4string
>>> $coords
>>> $data
>>>            site value cat        x       y
>>> 1Ai      81.80   1 825094.9 6796083
>>> 2     Al      38.50   2 758780.4 6851508
>>> 3     Ar     103.50   3 818973.3 6796125
>>> 4           Av      52.50   4 775136.0 6877271
>>> grass-stats mailing list
>>> grass-stats at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Edzer Pebesma
Institute for Geoinformatics (ifgi), University of Münster
Weseler Straße 253, 48151 Münster, Germany. Phone: +49 251
8333081, Fax: +49 251 8339763 http://ifgi.uni-muenster.de/
http://www.springer.com/978-0-387-78170-9 e.pebesma at wwu.de
More information about the grass-stats mailing list
