[GRASS-stats] Re: [R-sig-Geo] GRASS commands (fwd)
Markus Neteler neteler at cealp.it
Tue Sep 1 16:22:49 EDT 2009
2009/9/1 Roger Bivand <Roger.Bivand at nhh.no>:
 > Is this a bug in the interface description of v.mkgrid? It needs
 > grid=rows,columns but sets multiple=NO, so wxpython fails (needing two
 > values but getting one, but only providing an integer entry box).
It needs two values which are treated as one string, so it is correct.
(E.g. r.series accepts multiple input maps which are separate tokens which
required multiple=YES).
 >> grid=c(as.integer(100),as.integer(100)), box=c(5000, 5000),
 >> position="region"))
 >> returns
 >> Erreur dans doGRASS(cmd, flags = flags, parameters = parameters) :
 >>   Parameter <grid> has multiple values
 >> How do I specify the two values when multiple is not allowed. I did not
 >> get it....
You used
[1] 100 100
 > c(5000, 5000)
[1] 5000 5000
which leads to space separated values. But we want
 > paste(as.integer(100), as.integer(100), sep=",")
[1] "100,100"
 > Consider the statsgrass list for use of the interface between R and
GRASS,
 > in this case there is an interaction between a possible bug in
v.mkgrid and
 > the parsing of its parameters.
 > Since v.mkgrid does declare that grid does *not* take multiple
values, the
 > (current) logic of doGRASS() is defeated, as it checks that the multiple
 > attribute if the GRASS parameter is not "NO", see
http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.mkgrid/main.c#L74
 > The discrepancy between the code and the documentation is obvious.
There is no real discrepancy...
Hope above comments clarify it.
If not, we would need to see some debug output of doGRASS()...
Markus
Markus Neteler
Foundation Edmund Mach (FEM) - Research and Innovation Centre
Environment and Natural Resources Area
GIS and Remote Sensing Unit, Trento, Italy
Web:  http://gis.fem-environment.eu/
More information about the grass-stats mailing list
