[GRASS-dev] Re: [GRASS-stats] Sys.setlocale for GRASS6.4
Markus Neteler
neteler at osgeo.org
Fri Sep 4 16:38:33 EDT 2009
On Fri, Sep 4, 2009 at 9:26 PM, Glynn Clements<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> @grass-dev: There are encoding issues with --interface-description
>> which states UTF-8 also then the actual language encoding is different:
[then -> when]
> The --interface description option needs to either determine the
> locale's encoding via e.g. nl_langinfo() and use that in the header,
It seems to be already there?
lib/gis/parser.c:
static void G_usage_xml(void)
#if defined(HAVE_LANGINFO_H)
encoding = nl_langinfo(CODESET);
if (!encoding || strlen(encoding) == 0) {
encoding = "UTF-8";
#else
encoding = "UTF-8";
#endif
fprintf(stdout, "<?xml version=\"1.0\" encoding=\"%s\"?>\n", encoding);
fprintf(stdout, "<!DOCTYPE task SYSTEM \"grass-interface.dtd\">\n");
Apparently the Windows built was missing HAVE_LANGINFO_H or it
isn't properly set on Windows.
Markus
More information about the grass-stats
