[GRASS-stats] problem installing spgrass6 in R
    Roger Bivand
    Roger.Bivand at nhh.no
    Tue Sep 29 03:44:50 EDT 2009
On Mon, 28 Sep 2009, Hamish wrote:
> Tim:
>>> * Installing *source* package ‘bitops’ ...
>>> ** libs
>>> ** arch - i386
>>> sh: make: command not found
> you need to install 'make' which comes with gcc etc. from the
> Xcode(?) installer.
I think Tim needs to read the available FAQs on CRAN, and read:
http://r.research.att.com/tools/
giving the recipes for setting up an OSX system for building R packages.
It isn't hard, one just needs to folloow the instructions and *never*
assume anything unless one knows more about OSX variants than the
maintainer. I think that the underlying GRASS install is broken too
(probably PATH problems) wrt. GDAL.
Roger
> Hamish
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
