[GRASS-stats] Problem installing spdep
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Sep 29 07:05:37 EDT 2009
Wolf Bergenheim pisze:
> Hi,
> I have a problem when I try to install spdep I get the following error:
> Error: package 'Matrix' required by 'spdep' could not be found
> Execution halted
> ERROR: lazy loading failed for package 'spdep'
> ** Removing '/usr/local/lib/R/site-library/spdep'
> The downloaded packages are in
> 	/tmp/RtmpO1y8gG/downloaded_packages
> Warning messages:
> 1: In install.packages("spdep", dep = T) :
>   dependency ‘Matrix’ is not available
> 2: In install.packages("spdep", dep = T) :
>   installation of package 'spdep' had non-zero exit status
> What am I doing wrong? I tried installing it with
> install.packages("spdep", dep=T)
> --Wolf
 It looks like dependency issue...
use:
install.packages("spdep",dependencies=TRUE)
or try to install Matrix manually
Jarek
More information about the grass-stats mailing list
