[GRASS-stats] plugin and multiple GRASS instalation
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Tue Sep 29 10:55:25 EDT 2009
> Yes, if there is a plugin built against 5.7, or the 6.5-built plugin
> is seeing the 5.7 *.so shared objects, it will complain. I'm not sure
> that you can work around this easily - you would need not to use GDAL
> at all, I'm afraid, to be sure. My practice would most likely be to
> have two different users with local installs of everything and local
> LD path variables. The plugin "architecture" is designed for a single
> environment, one GDAL and one GRASS only in my experience.
I found other temporary solution: export LD_LIBRARY_PATH before starting
grass65 or grass7 and it works but it is not good solution
It rather pity information
best wishes
Jarek
More information about the grass-stats
