[GRASS-stats] problem installing spgrass6 in R
Tim Holland
timothyholland at gmail.com
Wed Sep 30 00:18:56 EDT 2009
I was just reading the R integration section of the KyngChaos page
(http://www.kyngchaos.com/software:grass#r_integration) and it said the
following:
R Integration
GRASS can be used with R (Tiger only). You should get the latest R binaries
(at least 2.3.0)...
That isn't true, is it? That it is Tiger (MacOSX 10.4) only? Should that
read Tiger and up? I am on Leopard (10.5), so if it only works on Tiger
that is a problem. For the time being, I will assume that it can work on
Leopard and will keep trying.
Best,
Tim
View this message in context: http://n2.nabble.com/problem-installing-spgrass6-in-R-tp3729191p3740630.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats
