[GRASS-stats] Re: [R-sig-Geo] Fail to load a vector layer using
	spgrass6
    Pierre Roudier
    pierre.roudier at gmail.com
    Mon Dec 13 17:26:52 EST 2010
Thank you for your answer Roger,
> Because there are two routes used depending on the setting of the plugin=
> argument, could you look at ogrDrivers() and see if you have an OGR GRASS
> vector driver, and if so, try to set plugin= manually to TRUE and FALSE?
The output of ogrDrivers() shows that I do not have the GRASS driver
(tagged as FALSE).
> Note that GRASS 7.0svn is the development version, snd is very much a moving
> target - do you have to use this version?
No, I do not have to use it, it is plein curiosity/testing of new
features. However I reproduced the problem on the 6.4 version.
> And GDAL 1.7.1 is not the current
> version, which is 1.7.3. Did you install GDAL and/or GRASS from source, or
> from binaries (in my experience, installing from source ensures more
> consistency, and the GDAL/OGR GRASS plugins are often the source of problems
> because of version mismatch).
I installed both GRASS 6.4 and GDAL/OGR from binaries, yes.
> PS. The best list is probably:
> http://grass.osgeo.org/statsgrass/index.php
OK. I am sending that message to that list, and keep R-sig-geo for
consistency. Sorry for cross-posting.
Thanks again,
Pierre
> Roger
> as it is more specific, and also seen by GRASS developers.
>> I tried to play with the different options but I did not succeed>
>> Here's more info about my data and platform:
>> Here is the output of v.info for the data I want to load:
>> GRASS 7.0.svn (NZTM2000):~ > v.info ph_cl
>> | Mapset:          nitrif_inhib
>> | Location:        NZTM2000
>> | Database:        /home/roudierp/Documents/GRASSDATA
>> | Title:
>> | Map scale:       1:1
>> | Map format:      native
>> | Name of creator: roudierp
>> | Organization:
>> | Source date:     Mon Dec 13 11:30:11 2010
>> |   Type of map: vector (level: 2)
>> |   Number of points:       0               Number of centroids:  236847
>> |   Number of lines:        0               Number of boundaries: 892041
>> |   Number of areas:        355021          Number of islands:    79124
>> |   Map is 3D:              No
>> |   Number of dblinks:      1
>> |   Projection: Transverse Mercator
>> |               N:  6190887.80270169    S:  4823266.04395524
>> |               E:  2091804.65744429    W:   1170289.3071784
>> |   Digitization threshold: 0
>> |   Comment:
>> And finally some metadata about the software packages I used:
>> here's the sessionInfo():
>>> sessionInfo()
>> R version 2.12.0 (2010-10-15)
>> Platform: x86_64-unknown-linux-gnu (64-bit)
>> locale:
>> [1] LC_CTYPE=en_GB.UTF-8       LC_NUMERIC=C
>> [3] LC_TIME=en_GB.UTF-8        LC_COLLATE=en_GB.UTF-8
>> [5] LC_MONETARY=C              LC_MESSAGES=en_GB.UTF-8
>> [7] LC_PAPER=en_GB.UTF-8       LC_NAME=C
>> [9] LC_ADDRESS=C               LC_TELEPHONE=C
>> [11] LC_MEASUREMENT=en_GB.UTF-8 LC_IDENTIFICATION=C
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>> [1] spgrass6_0.6-21 XML_3.2-0       rgdal_0.6-31    sp_0.9-74
>> loaded via a namespace (and not attached):
>> [1] grid_2.12.0     lattice_0.19-13
>>> library(spgrass6)
>> Loading required package: sp
>> Loading required package: rgdal
>> Geospatial Data Abstraction Library extensions to R successfully loaded
>> Loaded GDAL runtime: GDAL 1.7.1, released 2010/02/08
>> Path to GDAL shared files: /usr/share/gdal
>> Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
>> Path to PROJ.4 shared files: /usr/share/proj/
>> Loading required package: XML
>> GRASS GIS interface loaded with GRASS version: 7.0.svn
>> and location: NZTM2000
>> I got the last CRAN version of sp.
>> This runs on a linux machine:
>> GRASS 7.0.svn (NZTM2000):~ > uname -a
>> Linux A208_RoudierP 2.6.34.7-0.5-xen #1 SMP 2010-10-25 08:40:12 +0200
>> x86_64 x86_64 x86_64 GNU/Linux
>> Cheers,
>> Pierre
>> R-sig-Geo mailing list
>> R-sig-Geo at r-project.org
>> https://stat.ethz.ch/mailman/listinfo/r-sig-geo
> Roger Bivand
> Economic Geography Section, Department of Economics, Norwegian School of
> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
> e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
