[GRASS-stats] Re: [R-sig-Geo] Fail to load a vector layer using spgrass6
Pierre Roudier pierre.roudier at gmail.com
Tue Dec 14 16:58:15 EST 2010
Roger,
> The latest (0.6-23) spgrass6 has a fix for a specific problem in the layer
> parameter of v.out.ogr in GRASS7 - I see that you are using the previous
> spgrass6. Could you try updating spgrass6?
I did update and got the same error on both GRASS 6.4 and GRASS 7.0
> If that doesn't work, please move thread only to grass-stats, and try using
> v.out.ogr to export the vector to the GRASS mapset temporary directory
> manually - use g.tempfile to find out what the path to that directory is. If
> v.out.ogr appears to complete without problems, do check the temporary
> directory to be sure.
The output of g.tempfile is:
/home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/18058.0
When using that tempfile for export as Shapefile it fails:
v.out.ogr in=ph_cl
dsn='/home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/18058.0'
format=ESRI_Shapefile
WARNING: The map contains islands. To preserve them in the output map, use
         the -c flag
ERROR 1: /home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/18058.0
is not a directory.
ERROR: Unable to open OGR data source
However, if I specify the tmp folder that works:
v.out.ogr in=ph_cl
dsn='/home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/'
BUT - and that's where it gets tricky, if I want to use the GML
driver, this is the opposite situation:
v.out.ogr in=ph_cl
format=GML
ERROR 4: Failed to create GML file
/home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/.
While this works:
v.out.ogr in=ph_cl
dsn='/home/roudierp/Documents/GRASSDATA/NZTM2000/nitrif_inhib/.tmp/A208_RoudierP/18628.0'
format=GML
Exporting 355021 areas (may take some time)...
Any idea?
Pierre
> Roger
>>> And GDAL 1.7.1 is not the current
>>> version, which is 1.7.3. Did you install GDAL and/or GRASS from source,
>>> or
>>> from binaries (in my experience, installing from source ensures more
>>> consistency, and the GDAL/OGR GRASS plugins are often the source of
>>> problems
>>> because of version mismatch).
>> I installed both GRASS 6.4 and GDAL/OGR from binaries, yes.
>>> PS. The best list is probably:
>>> http://grass.osgeo.org/statsgrass/index.php
>> OK. I am sending that message to that list, and keep R-sig-geo for
>> consistency. Sorry for cross-posting.
>> Thanks again,
>> Pierre
>>> Roger
>>> as it is more specific, and also seen by GRASS developers.
>>>> I tried to play with the different options but I did not succeed>
>>>> Here's more info about my data and platform:
>>>> Here is the output of v.info for the data I want to load:
>>>> GRASS 7.0.svn (NZTM2000):~ > v.info ph_cl
>>>> | Mapset:          nitrif_inhib
>>>> | Location:        NZTM2000
>>>> | Database:        /home/roudierp/Documents/GRASSDATA
>>>> | Title:
>>>> | Map scale:       1:1
>>>> | Map format:      native
>>>> | Name of creator: roudierp
>>>> | Organization:
>>>> | Source date:     Mon Dec 13 11:30:11 2010
>>>> |   Type of map: vector (level: 2)
>>>> |   Number of points:       0               Number of centroids:  236847
>>>> |   Number of lines:        0               Number of boundaries: 892041
>>>> |   Number of areas:        355021          Number of islands:    79124
>>>> |   Map is 3D:              No
>>>> |   Number of dblinks:      1
>>>> |   Projection: Transverse Mercator
>>>> |               N:  6190887.80270169    S:  4823266.04395524
>>>> |               E:  2091804.65744429    W:   1170289.3071784
>>>> |   Digitization threshold: 0
>>>> |   Comment:
>>>> And finally some metadata about the software packages I used:
>>>> here's the sessionInfo():
>>>>> sessionInfo()
>>>> R version 2.12.0 (2010-10-15)
>>>> Platform: x86_64-unknown-linux-gnu (64-bit)
>>>> locale:
>>>> [1] LC_CTYPE=en_GB.UTF-8       LC_NUMERIC=C
>>>> [3] LC_TIME=en_GB.UTF-8        LC_COLLATE=en_GB.UTF-8
>>>> [5] LC_MONETARY=C              LC_MESSAGES=en_GB.UTF-8
>>>> [7] LC_PAPER=en_GB.UTF-8       LC_NAME=C
>>>> [9] LC_ADDRESS=C               LC_TELEPHONE=C
>>>> [11] LC_MEASUREMENT=en_GB.UTF-8 LC_IDENTIFICATION=C
>>>> attached base packages:
>>>> [1] stats     graphics  grDevices utils     datasets  methods   base
>>>> other attached packages:
>>>> [1] spgrass6_0.6-21 XML_3.2-0       rgdal_0.6-31    sp_0.9-74
>>>> loaded via a namespace (and not attached):
>>>> [1] grid_2.12.0     lattice_0.19-13
>>>>> library(spgrass6)
>>>> Loading required package: sp
>>>> Loading required package: rgdal
>>>> Geospatial Data Abstraction Library extensions to R successfully loaded
>>>> Loaded GDAL runtime: GDAL 1.7.1, released 2010/02/08
>>>> Path to GDAL shared files: /usr/share/gdal
>>>> Loaded PROJ.4 runtime: Rel. 4.7.1, 23 September 2009
>>>> Path to PROJ.4 shared files: /usr/share/proj/
>>>> Loading required package: XML
>>>> GRASS GIS interface loaded with GRASS version: 7.0.svn
>>>> and location: NZTM2000
>>>> I got the last CRAN version of sp.
>>>> This runs on a linux machine:
>>>> GRASS 7.0.svn (NZTM2000):~ > uname -a
>>>> Linux A208_RoudierP 2.6.34.7-0.5-xen #1 SMP 2010-10-25 08:40:12 +0200
>>>> x86_64 x86_64 x86_64 GNU/Linux
>>>> Cheers,
>>>> Pierre
>>>> _______________________________________________
>>>> R-sig-Geo mailing list
>>>> R-sig-Geo at r-project.org
>>>> https://stat.ethz.ch/mailman/listinfo/r-sig-geo
>>> Roger Bivand
>>> Economic Geography Section, Department of Economics, Norwegian School of
>>> Economics and Business Administration, Helleveien 30, N-5045 Bergen,
>>> Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
>>> e-mail: Roger.Bivand at nhh.no
> Roger Bivand
More information about the grass-stats mailing list
