[GRASS-stats] assertion failure on call to r.cost & v.what.rast
    Colin Bleay
    Colin.bleay at bristol.ac.uk
    Wed Dec 15 13:02:08 EST 2010
I am running a script in R that calls functions in grass from a
iterative loop.
This works fine but every so often I get an assertion failure.
This does not appear to be a function of the data I am sending to the
grass executable.
The assertion failure throws up a window allowing me to 'abort', 'retry'
or 'ignore'.
If i 'retry' it then asks me to close the program (the grass executable)
and then the R script carries on as usual. i.e. the retry works and I
will end up with all my data.
The problem i have is that I wish to let this r script run over night
but i cannot as I have to be there to supervise it, to 'retry' the commands.
so my questions are:
1. Does any body have any idea why these assertion failures are occuring?
2. Does anybody have any idea how I might be able to catch these
failures so that I can get R to retry the grass executable rather than
myself.
the error the grass executable throws is:
"Assertion failed!
Program: C\GRASS_64\bin\RCOST~1.EXE
File:r:\pismere\athena\auth\krb5\scr\li..\g_initialize.c
Line:76
Expression: (&(&g_mechListLock)->os)->is_locked==1"
More information about the grass-stats
