[GRASS-stats] Re: GRASS-R connection in Windows
Martin Mainzer
martmai at gmx.de
Mon Sep 27 14:36:58 EDT 2010
Hi Abdoul
schrieb Abdoul Dia am 27.09.2010 19:00:
> Hi everyone,
> I'm wondering if I can ask my question here as I'm not sure to be on
> the right place?! I'm trying to connect Grass 6.4 with R.2.11 so I can
> use spgrass6 and GRASS packages under R but I can't get the gmeta() or
> gmeta6() output. I can't even install spgrass6 on linux. I tried on
> windows as well as on linux (ubuntu karmic). Is there someone who
> faced such a problem and how can I solve?
Please give us more information, what is the problem with the spgrass6
package? Without the spgrass6 library loaded, the gmeta6() output will
not work. If you got a problem with installing the spgrass6 package in
R, it may be a good idea to contact the R mailinglist.
Martin
> Thanks in advance.
> Abdoul O. Dia
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20100927/4da925df/attachment.html
More information about the grass-stats
