[GRASS-stats] Re: GRASS-R connection in Windows
Helmut Kudrnovsky hellik at web.de
Mon Sep 27 17:58:45 EDT 2010
Hi Antonio
>-----Ursprüngliche Nachricht-----
>Von: "António Rocha"
>Gesendet: 27.09.2010 11:27:43
>An: "Helmut Kudrnovsky"
>Betreff: Re: GRASS-R connection in Windows
>Hello Helmut
>First of all, let me thank you for your reply.
de nada
>Helmut Kudrnovsky wrote:
>> (2) you can start "Grass-command-line" - it's a windows-command-line, not a msys-rxvt-terminal (you can find this
>> starting option under Programs -> Grass64 -> Grass command line; but not as a desktop icon)
>Here I have a question: Is it possible to run a GRASS-Python Script with
>R-commands just like a normal GRASS-Python Script? (without having to
>run R in command-line)- I believe it has to do with Ticket #1103 right?
>Best regards,
>Antonio Rocha
sorry, but I've never used Grass, R and python together. so it's outside of my knowledge. maybe drop this question
also at the user- and/or dev-mailing-list.
at the moment for WinGrass, the R-installation-path is recognized only once at the WinGrass-installation-procedure and set into the %PATH-variable,
so no future upgrade of a R-version will be recognized by the wingrass-installation.
the intention of ticket #1103 would be to set the R-installation-path dynamically at every start of a grass-session.
best regards
Helmut
___________________________________________________________
GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
More information about the grass-stats mailing list
