[GRASS-stats] Installing Grass on R
daniel mcinerney
daniel.o.mcinerney at gmail.com
Fri May 6 17:04:28 EDT 2011
Hi Eric,
Which installation instructions are you referring to?
You should first ensure that you have GRASS-GIS installed
on your system. You'll find detailed instructions about
installing GRASS from source or an rpm here [1].
Once you have successfully installed GRASS, you should
then install the R package, spgrass6 [2]. This can be
done from within R by running the command:
>install.packages("spgrass6", dep=TRUE)
Further instructions can be found here [3]. You should
then be able to access GRASS from R [4].
Hope this is of use. Let us know if you have further
questions.
Regards,
Daniel.
[1] http://grass.osgeo.org/wiki/Installation_Guide
[2] http://cran.r-project.org/web/packages/spgrass6/index.html
[3] http://grass.osgeo.org/wiki/R_statistics#Installation
[4] http://grass.osgeo.org/wiki/R_statistics#Running
2011/5/6 Eric Kaufmann <kaufmann at slu.edu>
> I am trying to install GRASS on R. We are using Cento OS. According to the
> installation instructions, the most current rpm should contain Grass.
> Is this correct?
> Thanks,
> Eric
> Eric Kaufmann | Application Support Analyst - Advanced Technology Group
> | Saint Louis University | 314-977-2257 | kaufmann at slu.edu
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: http://lists.osgeo.org/pipermail/grass-stats/attachments/20110506/c0ec7691/attachment.html
More information about the grass-stats
