[GRASS-stats] Problem with v.distance in spgrass6 package in R
Roger Bivand Roger.Bivand at nhh.no
Fri Oct 28 04:59:25 EDT 2011
On Fri, 28 Oct 2011, toke wrote:
> I think that I might have found a bug in spgrass6 or I might be doing
> something wrong. When I call v.distance within R it seems to calculate but
> it do not update the column of interest.
> Im using the the following software:
> platform    x86_64-pc-linux-gnu 10.10
> language   R
> version.string R version 2.13.2 (2011-09-30)
> Here are my script
> R
> #calling library
> library(spgrass6)
> # checking GRASS setup
> gmeta6()
> output:
> gisdbase    /home/toke/Desktop/PHD/databehandling/artikel_3/gis/grassdb
> location    mapset
> mapset      aalborg
> rows        1200
> columns     1100
> north       6328400
> south       6316400
> west        551800
> east        562800
> nsres       10
> ewres       10
> projection  +proj=utm +no_defs +zone=32 +a=6378137 +rf=298.257222101
> +to_meter=1
> # reading spatial files from GRASS database
> recrea_h <-readVECT6("recrea_h")
> area_b1 <-readVECT6("area_b1")
> execGRASS("v.distance", flags=c("overwrite"), from="recrea_h", to="area_b1",
> from_type="centroid", to_type="area", dmax=as.integer(1),
> + upload="to_attr", column="area_b1", to_column="value")
> 100%
> 100%
> 84 categories - no nearest feature found
> 235 categories read from the map
> 235 categories exist in the table
> 235 categories read from the map exist in the table
> 235 records updated
> v.distance complete.
> The column is not updated even though it seems that it is actually are
> calculating.
> The same calculation in GRASS works.
Please show your exact GRASS command line - otherwise we can only conclude
that you are asking for different things. You are asking for a maximum
distance of integer 1 metres here, so you should look carefully at the 84
categories - no nearest feature found message - did that also appear in
the output from running the command directly in GRASS?
Roger
> Cheers Toke
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-v-distance-in-spgrass6-package-in-R-tp6939286p6939286.html
> Sent from the Grass - Stats mailing list archive at Nabble.com.
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
