[GRASS-stats] spgrass7 support for strds?
Rainer M Krug Rainer at krugs.de
Wed Feb 11 05:52:44 PST 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
> Since I'm uncertain whether the maintainer of spacetime is on this
> list, I'm CC-ing him here. It might make sense to discuss this -
> perhaps spgrass7 in the R-forge spgrass project is a logical place to
> support these functions?
It is a brilliant idea to support spatio-temporal data in the spgrass7
framework.
I agree that the functions should be in spgrass7 and that they should
have the same interface structure as the other read/write[RAST/VECT]
functions.
I never used the package spacetime or spatio-temporal datasets in GRASS,
but maybe these functions could be re-used (or at least parts of it)?
But this should not hold back the release of spgrass7 in it's current
form.
Cheers,
Rainer
> Roger
> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>> Hi
>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>> includes these great temporal modules), I was wondering if there's any
>> chance to include support for reading/writing spatio-temporal data sets.
>> At present, there are two functions in spacetime package (read.tgrass and
>> write.tgrass) that allows reading and writing strds, but you need to export
>> it from GRASS first, do the R processing you need, and then, import it back
>> into GRASS. To have something a bit more straightforward would be awesome!
>> I don't know how complicated this could be, that's why I dare to ask :)
>> Keep the great job you are doing!!! And thanks a lot!!!
>> Cheers,
>> Vero
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150211/df8379fb/attachment.pgp>
More information about the grass-stats mailing list
