[GRASS-stats] spgrass7 support for strds?
Rainer M Krug Rainer at krugs.de
Wed Feb 11 06:42:57 PST 2015
Edzer Pebesma <edzer.pebesma at uni-muenster.de> writes:
> On 02/11/2015 02:52 PM, Rainer M Krug wrote:
>> Roger Bivand <Roger.Bivand at nhh.no> writes:
>>> Since I'm uncertain whether the maintainer of spacetime is on this
>>> list, I'm CC-ing him here. It might make sense to discuss this -
>>> perhaps spgrass7 in the R-forge spgrass project is a logical place to
>>> support these functions?
>> It is a brilliant idea to support spatio-temporal data in the spgrass7
>> framework.
>> I agree that the functions should be in spgrass7 and that they should
>> have the same interface structure as the other read/write[RAST/VECT]
>> functions.
>> I never used the package spacetime or spatio-temporal datasets in GRASS,
>> but maybe these functions could be re-used (or at least parts of it)?
> yes; and use the TGRASS (Cc: Soeren, the author), framework. Also,
> raster stacks with time z should be of interest (Cc: Robert).
Please forgive my ignorance - but is there actually an accepted (as
SpatialGridDataFrame et al are accepted) object framework for these
spatio-temporal datasets in R? It sounds as if there is not at the moment?
>> But this should not hold back the release of spgrass7 in it's current
>> form.
> I suggest to rename this package to "grass", supporting the current
> grass release.
> Grass took 7 years to move 6 to 7; I discussed this with Markus last
> night, they might as well give up this crazy major version release cycle
> idea, with all kind of restrictions they impose on themselves.
This might cause confusion. And as long as GRASS has major versions, I
think we should stick with this naming scheme.
Cheers,
Rainer
>> Cheers,
>> Rainer
>>> Roger
>>> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>>>> Hi
>>>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>>>> includes these great temporal modules), I was wondering if there's any
>>>> chance to include support for reading/writing spatio-temporal data sets.
>>>> At present, there are two functions in spacetime package (read.tgrass and
>>>> write.tgrass) that allows reading and writing strds, but you need to export
>>>> it from GRASS first, do the R processing you need, and then, import it back
>>>> into GRASS. To have something a bit more straightforward would be awesome!
>>>> I don't know how complicated this could be, that's why I dare to ask :)
>>>> Keep the great job you are doing!!! And thanks a lot!!!
>>>> Cheers,
>>>> Vero
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150211/36bed7f6/attachment.pgp>
More information about the grass-stats mailing list
