[GRASS-stats] spgrass7 support for strds?
Rainer M Krug Rainer at krugs.de
Thu Feb 12 02:51:25 PST 2015
Roger Bivand <Roger.Bivand at nhh.no> writes:
> Question further down ...
> On Wed, 11 Feb 2015, Edzer Pebesma wrote:
>> On 02/11/2015 03:42 PM, Rainer M Krug wrote:
>>> Edzer Pebesma <edzer.pebesma at uni-muenster.de> writes:
>>>>>> Since I'm uncertain whether the maintainer of spacetime is on this
>>>>>> list, I'm CC-ing him here. It might make sense to discuss this -
>>>>>> perhaps spgrass7 in the R-forge spgrass project is a logical place to
>>>>>> support these functions?
>>>>> It is a brilliant idea to support spatio-temporal data in the spgrass7
>>>>> framework.
>>>>> I agree that the functions should be in spgrass7 and that they should
>>>>> have the same interface structure as the other read/write[RAST/VECT]
>>>>> functions.
>>>>> I never used the package spacetime or spatio-temporal datasets in GRASS,
>>>>> but maybe these functions could be re-used (or at least parts of it)?
>>>> yes; and use the TGRASS (Cc: Soeren, the author), framework. Also,
>>>> raster stacks with time z should be of interest (Cc: Robert).
>>> Please forgive my ignorance - but is there actually an accepted (as
>>> SpatialGridDataFrame et al are accepted) object framework for these
>>> spatio-temporal datasets in R? It sounds as if there is not at the moment?
>> When is something accepted? raster and spacetime have both been on CRAN
>> for some years, and have both been considered useful by people
>> independent from the developers. There is a SpatioTemporal task view
>> that tries to list everything possibly relevant.
>>>>> But this should not hold back the release of spgrass7 in it's current
>>>>> form.
>>>> I suggest to rename this package to "grass", supporting the current
>>>> grass release.
>>>> Grass took 7 years to move 6 to 7; I discussed this with Markus last
>>>> night, they might as well give up this crazy major version release cycle
>>>> idea, with all kind of restrictions they impose on themselves.
>>> This might cause confusion. And as long as GRASS has major versions, I
>>> think we should stick with this naming scheme.
>> We don't do this with rgdal, rgeos, RSAGA, RArcInfo, and so on. But many
>> of these have an "r" in front. This seems obsolete as they are R
>> packages, but may be helpful in sentences like "We used grass and the
>> r-package rgrass for carrying out multidimensional scaling on the MODIS
>> imagery ...", which, without the leading r, would have the word "grass"
>> twice in it referring to different things.
>> spgrass has sp in it for historic reasons - we thought about prefixing
>> everything with sp in the early sp days. Now sp is default, and one
>> could think about a better name.
> OK, I think we keep (archived) "GRASS" for the interface to GRASS 5,
> "spgrass6" for GRASS 6. As of now, we've called the development
> version "spgrass7", but arguably "rgrass" could be preferred. As GRASS
> 7 is due on Sunday, could I ask for a quick show of hands on
> "spgrass7" or "rgrass" as the name for the package to be submitted to
> CRAN (tomorrow)? We can continue to consider moving spacetime code to
> this package, but we should have the new package on CRAN matching the
> release of GRASS 7.
The r in front makes sense - but if one looks at the changes in the
interface between GRASS 6 and GRASS 7 I would keep the 7 - so I would
suggest
rgrass7
and possibly also release the (modified) spgrass6 as rgrass6, and leave
spgrass6 there for compatibility, and give a warning upon load that the
package has been superseded by rgrass6.
This also opens the possibility of releasing a package called
rgrass
which then, depending on the GRASS version loaded / requested loads the
corresponding rgrassX package.
Rainer
> Roger
>>> Cheers,
>>> Rainer
>>>>> Cheers,
>>>>> Rainer
>>>>>> Roger
>>>>>> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>>>>>>> Hi
>>>>>>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>>>>>>> includes these great temporal modules), I was wondering if there's any
>>>>>>> chance to include support for reading/writing spatio-temporal data sets.
>>>>>>> At present, there are two functions in spacetime package (read.tgrass and
>>>>>>> write.tgrass) that allows reading and writing strds, but you need to export
>>>>>>> it from GRASS first, do the R processing you need, and then, import it back
>>>>>>> into GRASS. To have something a bit more straightforward would be awesome!
>>>>>>> I don't know how complicated this could be, that's why I dare to ask :)
>>>>>>> Keep the great job you are doing!!! And thanks a lot!!!
>>>>>>> Cheers,
>>>>>>> Vero
>>>>> _______________________________________________
>>>>> grass-stats mailing list
>>>>> grass-stats at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150212/5776b271/attachment.pgp>
More information about the grass-stats mailing list
