[GRASS-stats] spgrass7 support for strds?
Rainer M Krug
Rainer at krugs.de
Thu Feb 12 06:54:17 PST 2015
Just for clarification - the rgrass solution would mean:
GRASS for GRASS 5
spgrass6 for GRASS 6
rgrass for GRASS 7
If this is correct, then it is very confusing.
To re-iterate:
I like the rgrass, but
rgrass6 and rgrass7
would make things clearer.
Rainer
Edzer Pebesma <edzer.pebesma at uni-muenster.de> writes:
> I'm in favour of rgrass.
> On 02/12/2015 12:13 PM, Ahmadou Dicko wrote:
>> I will also cast my vote in favor of 'rgrass' because of the consistency
>> with other library and gis linked to R (RSAGA, rgeos, rgdal, etc.).
>> We can just then make sure that it works with both version of GRASS (6
>> and 7).
>> I also started a project (idea) a long time ago with Rainer to have
>> something similar to pygrass[1] in R through Rcpp
>> (https://github.com/RGRASS/grassRLink) in order to access the low level
>> GRASS API.
>> I didn't have time to finish it but I will have more time this summer
>> and hope to work on it again.
>> I think it can be a good idea of GSOC for either GRASS or R.
>> [1]: http://grasswiki.osgeo.org/wiki/Python/pygrass
>> On Thu, Feb 12, 2015 at 10:51 AM, Rainer M Krug <Rainer at krugs.de
>> <mailto:Rainer at krugs.de>> wrote:
>> Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no>> writes:
>> > Question further down ...
>> > On Wed, 11 Feb 2015, Edzer Pebesma wrote:
>> <mailto:edzer.pebesma at uni-muenster.de>> writes:
>> >>>>>> Since I'm uncertain whether the maintainer of spacetime is on
>> this
>> >>>>>> list, I'm CC-ing him here. It might make sense to discuss this -
>> >>>>>> perhaps spgrass7 in the R-forge spgrass project is a logical
>> place to
>> >>>>>> support these functions?
>> >>>>> It is a brilliant idea to support spatio-temporal data in the
>> spgrass7
>> >>>>> framework.
>> >>>>> I agree that the functions should be in spgrass7 and that they
>> should
>> >>>>> have the same interface structure as the other
>> read/write[RAST/VECT]
>> >>>>> functions.
>> >>>>> I never used the package spacetime or spatio-temporal datasets
>> in GRASS,
>> >>>>> but maybe these functions could be re-used (or at least parts
>> of it)?
>> >>>> yes; and use the TGRASS (Cc: Soeren, the author), framework. Also,
>> >>>> raster stacks with time z should be of interest (Cc: Robert).
>> >>> Please forgive my ignorance - but is there actually an accepted (as
>> >>> SpatialGridDataFrame et al are accepted) object framework for these
>> >>> spatio-temporal datasets in R? It sounds as if there is not at
>> the moment?
>> >> When is something accepted? raster and spacetime have both been
>> on CRAN
>> >> for some years, and have both been considered useful by people
>> >> independent from the developers. There is a SpatioTemporal task view
>> >> that tries to list everything possibly relevant.
>> >>>>> But this should not hold back the release of spgrass7 in it's
>> current
>> >>>>> form.
>> >>>> I suggest to rename this package to "grass", supporting the current
>> >>>> grass release.
>> >>>> Grass took 7 years to move 6 to 7; I discussed this with Markus
>> last
>> >>>> night, they might as well give up this crazy major version
>> release cycle
>> >>>> idea, with all kind of restrictions they impose on themselves.
>> >>> This might cause confusion. And as long as GRASS has major
>> versions, I
>> >>> think we should stick with this naming scheme.
>> >> We don't do this with rgdal, rgeos, RSAGA, RArcInfo, and so on.
>> But many
>> >> of these have an "r" in front. This seems obsolete as they are R
>> >> packages, but may be helpful in sentences like "We used grass and the
>> >> r-package rgrass for carrying out multidimensional scaling on the
>> MODIS
>> >> imagery ...", which, without the leading r, would have the word
>> "grass"
>> >> twice in it referring to different things.
>> >> spgrass has sp in it for historic reasons - we thought about
>> prefixing
>> >> everything with sp in the early sp days. Now sp is default, and one
>> >> could think about a better name.
>> > OK, I think we keep (archived) "GRASS" for the interface to GRASS 5,
>> > "spgrass6" for GRASS 6. As of now, we've called the development
>> > version "spgrass7", but arguably "rgrass" could be preferred. As GRASS
>> > 7 is due on Sunday, could I ask for a quick show of hands on
>> > "spgrass7" or "rgrass" as the name for the package to be submitted to
>> > CRAN (tomorrow)? We can continue to consider moving spacetime code to
>> > this package, but we should have the new package on CRAN matching the
>> > release of GRASS 7.
>> The r in front makes sense - but if one looks at the changes in the
>> interface between GRASS 6 and GRASS 7 I would keep the 7 - so I would
>> suggest
>> rgrass7
>> and possibly also release the (modified) spgrass6 as rgrass6, and leave
>> spgrass6 there for compatibility, and give a warning upon load that the
>> package has been superseded by rgrass6.
>> This also opens the possibility of releasing a package called
>> rgrass
>> which then, depending on the GRASS version loaded / requested loads the
>> corresponding rgrassX package.
>> Rainer
>> > Roger
>> >>> Cheers,
>> >>> Rainer
>> >>>>> Cheers,
>> >>>>> Rainer
>> >>>>>> Roger
>> >>>>>> On Wed, 11 Feb 2015, Veronica Andreo wrote:
>> >>>>>>> Hi
>> >>>>>>> Since you are discussing the new spgrass for GRASS 7 (and since GRASS 7
>> >>>>>>> includes these great temporal modules), I was wondering if there's any
>> >>>>>>> chance to include support for reading/writing spatio-temporal data sets.
>> >>>>>>> At present, there are two functions in spacetime package (read.tgrass and
>> >>>>>>> write.tgrass) that allows reading and writing strds, but you need to export
>> >>>>>>> it from GRASS first, do the R processing you need, and then, import it back
>> >>>>>>> into GRASS. To have something a bit more straightforward would be awesome!
>> >>>>>>> I don't know how complicated this could be, that's why I dare to ask :)
>> >>>>>>> Keep the great job you are doing!!! And thanks a lot!!!
>> >>>>>>> Cheers,
>> >>>>>>> Vero
>> >>>>> _______________________________________________
>> >>>>> grass-stats mailing list
>> >>>>> grass-stats at lists.osgeo.org <mailto:grass-stats at lists.osgeo.org>
>> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-stats
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> <tel:%2B33%20-%20%280%299%2053%2010%2027%2044>
>> Cell: +33 - (0)6 85 62 59 98
>> <tel:%2B33%20-%20%280%296%2085%2062%2059%2098>
>> Fax : +33 - (0)9 58 10 27 44
>> <tel:%2B33%20-%20%280%299%2058%2010%2027%2044>
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> <tel:%2B49%20-%20%280%293%2021%2021%2025%2022%2044>
>> email: Rainer at krugs.de <mailto:Rainer at krugs.de>
>> Skype: RMkrug
>> PGP: 0x0F52F982
>> Ahmadou H. DICKO
>> statistician economist (Ingénieur Statisticien Économiste)
>> PhD candidate in Climate change economics
>> Faculty of economics and managment - Cheikh Anta Diop University
>> West African Science Service Center on Climate Change and Adaptated Land
>> Use (WASCAL)
>> Center for Development Research (ZEF) - University of Bonn
>> email : ahmadou.dicko at ucad.edu.sn <mailto:ahmadou.dicko at ucad.edu.sn>
>> twitter : @dickoah
>> github : github/dickoa <https://github.com/dickoa>
>> tel : +221 33 827 55 16
>> portable: +221 77 123 81 69
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150212/a3aa7193/attachment.pgp>
More information about the grass-stats
