[GRASS-stats] Towards spgrass7
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Mon Jan 19 12:55:28 PST 2015
Dear Roger Bivand
Thank you very much for making this updated version available. I normally
use GRASS on Linux (where spgrass runs fine with my admittedly limited
testing), but I tried the examples from readVECT and readRAST on a Windows
installation. They ran without problems, with the note that I had to run
the readRAST functions with plugin=FALSE or plugin=NULL (is this because
the grass-rgdal plugin is not working properly perhaps?).
I did get an warning message when running readRAST (with plugin=FALSE),
e.g.,
> quads0 <- readRAST("quads0", plugin=FALSE)
Warning message: running command 'r.out.gdal.exe -c --quiet input=quads0
output=C:/GIS/GrassJvdS/spearfish60/user1/.tmp/unknown/quads0 type=Int32
format=GTiff' had status 1
About the help file of readRAST, one syntax change did not get through:
execGRASS("g.region", rast="elevation.dem")
This should be:
execGRASS("g.region", raster="elevation.dem")
Best wishes,
Paulo
On Mon, Jan 19, 2015 at 7:50 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Thu, 15 Jan 2015, Markus Neteler wrote:
>  Dear Roger,
>> On Thu, Jan 15, 2015 at 1:10 PM, Roger Bivand <Roger.Bivand at nhh.no>
>> wrote:
>>> Dear Markus,
>>> Good to hear you are well! Great that RC1 is ready!
>> Yeah, it took us a while but the latest cleanup efforts where really
>> important. I expect that we will proceed from RC1 to final release rather
>> fast (finally!).
>>  Yes, I guess it would be sensible to condition on version in these
>>> cases, so
>>> first add comments for hard-coded flags and options (there are also some
>>> changes in type, I think). In addition, bin_out_win in parseGRASS() needs
>>> updating and/or conditioning on version, and the logic for handling where
>>> Python scripts are found should be looked at.
>> Yes, fine.
>>  You do not (yet) have commit rights on:
>>> https://r-forge.r-project.org/projects/rspatial/ where spgrass6 lives.
>> I have now registered on R-Forge.
>>  Two alignments: should GRASS5 support (GRASS packages) be dropped (yes)?
>> Yes, dropped.
>>  Should spgrass6 be forked into (new) spgrass which supports >= 7, and
>>> leave
>>> spgrass6 for 6.*?
>> I'd support to fork in order to not have too many conditions in the code.
>>  If fork, is SVN on R-Forge OK?
>> Yes.
> After forking, as of now:
> install.packages("spgrass", repos="http://R-Forge.R-project.org")
> installs the "new" package for GRASS 7. Function names are now without the
> trailing 6 to avoid confusion, and all examples run correctly in Spearfish
> in GRASS 7.0 RC1.
> Could someone please run the examples in Spearfish in GRASS 7.0 RC1 on
> Windows after installing the Windoes spgrass binary (R 3.1) from R-Forge,
> and report back?
> Could someone please install spgrass from source on OSX (pre-Yosemite and
> Yosemite), run the examples in Spearfish, and report back?
> The existing spgrass6 does not work with GRASS 7 following recent changes
> in GRASS parameter names - it may be modified either to permit these, or to
> remove GRASS 7 conditions, leaving it just for GRASS 6.
> Best wishes,
> Roger
>> Best wishes,
>> Markus
> Roger Bivand
> Department of Economics, Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; fax +47 55 95 91 00
> e-mail: Roger.Bivand at nhh.no
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150119/8b2b0c04/attachment.html>
More information about the grass-stats
