[GRASS-stats] Towards spgrass7
Roger Bivand
Roger.Bivand at nhh.no
Wed Jan 21 00:41:31 PST 2015
On Tue, 20 Jan 2015, Rainer M Krug wrote:
> Sorry if this has been received before - but I don't seem to be able to
> post via gmane?
Sorry, don't know about gmane.
> Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
>> On Thu, 15 Jan 2015, Markus Neteler wrote:
>>> Dear Roger,
>>> On Thu, Jan 15, 2015 at 1:10 PM, Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> wrote:
>>>> Dear Markus,
>>>> Good to hear you are well! Great that RC1 is ready!
>>> Yeah, it took us a while but the latest cleanup efforts where really
>>> important. I expect that we will proceed from RC1 to final release
>>> rather fast (finally!).
>>>> Yes, I guess it would be sensible to condition on version in these cases, so
>>>> first add comments for hard-coded flags and options (there are also some
>>>> changes in type, I think). In addition, bin_out_win in parseGRASS() needs
>>>> updating and/or conditioning on version, and the logic for handling where
>>>> Python scripts are found should be looked at.
>>> Yes, fine.
>>>> You do not (yet) have commit rights on:
>>>> https://r-forge.r-project.org/projects/rspatial/ where spgrass6 lives.
>>> I have now registered on R-Forge.
>>>> Two alignments: should GRASS5 support (GRASS packages) be dropped (yes)?
>>> Yes, dropped.
>>>> Should spgrass6 be forked into (new) spgrass which supports >= 7, and leave
>>>> spgrass6 for 6.*?
>>> I'd support to fork in order to not have too many conditions in the code.
>>>> If fork, is SVN on R-Forge OK?
>>> Yes.
>> After forking, as of now:
>> install.packages("spgrass", repos="http://R-Forge.R-project.org")
>> installs the "new" package for GRASS 7. Function names are now without
>> the trailing 6 to avoid confusion, and all examples run correctly in
>> Spearfish in GRASS 7.0 RC1.
>> Could someone please run the examples in Spearfish in GRASS 7.0 RC1 on
>> Windows after installing the Windoes spgrass binary (R 3.1) from
>> R-Forge, and report back?
>> Could someone please install spgrass from source on OSX (pre-Yosemite
>> and Yosemite), run the examples in Spearfish, and report back?
> I installed now spgrass and have the GRASS 7 Spearfish dataset. Which
> examples are you referring to to be run?
Thanks for looking. I provided commit rights on R-forge, so if you see
things that need fixing, please do so!
(Yosemite should have been Mavericks, of course). The examples are on the
help pages, so running R inside GRASS 7 something like:
library(spgrass)
example(execGRASS)
example(gmeta)
example(spgrass)
example(readRAST)
example(readVECT)
interactively would be a possibility.
I guess that the package will move to nc_basic to align better with GRASS
7.
Best wishes,
Roger
> Rainer
>> The existing spgrass6 does not work with GRASS 7 following recent
>> changes in GRASS parameter names - it may be modified either to permit
>> these, or to remove GRASS 7 conditions, leaving it just for GRASS 6.
>> Best wishes,
>> Roger
>>> Best wishes,
>>> Markus
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
