[GRASS-stats] errors on spgrass Yosemite / homebrew
Roger Bivand Roger.Bivand at nhh.no
Wed Jan 21 00:47:37 PST 2015
We are testing against RC1, and some (many) parameter names were changed
between beta3 (2014-08-05) and RC1 (2015-01-14) I think. I believe that
the parameter and flag names have been being simlified and made consistent
across modules.
Roger
On Wed, 21 Jan 2015, Rainer M Krug wrote:
> Hi
> I tried to run
> --8<---------------cut here---------------start------------->8---
> library(spgrass)
> examples(spgrass)
> --8<---------------cut here---------------end--------------->8---
> but I got an error - transcript below.
> Let me know if I should try something out.
> Cheers,
> Rainer
> | 09:30:33 ~$ grass70 ~/Documents/spearfish60_grass7/user1/
> | Cleaning up temporary files...
> | Starting GRASS GIS...
> |           __________  ___   __________    _______________
> |          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
> |         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
> |        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
> |        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> | Welcome to GRASS 7.0.0beta3
> | GRASS homepage:                          http://grass.osgeo.org
> | This version running through:            Bash Shell (/usr/local/bin/bash)
> | Help is available with the command:      g.manual -i
> | See the licence terms with:              g.version -c
> | Start the GUI with:                      g.gui wxpython
> | When ready to quit enter:                exit
> | GRASS 7.0.0beta3 (spearfish60_grass7):~ > R
> | R version 3.1.2 (2014-10-31) -- "Pumpkin Helmet"
> | Copyright (C) 2014 The R Foundation for Statistical Computing
> | Platform: x86_64-apple-darwin14.1.0 (64-bit)
> | R is free software and comes with ABSOLUTELY NO WARRANTY.
> | You are welcome to redistribute it under certain conditions.
> | Type 'license()' or 'licence()' for distribution details.
> |   Natural language support but running in an English locale
> | R is a collaborative project with many contributors.
> | Type 'contributors()' for more information and
> | 'citation()' on how to cite R or R packages in publications.
> | Type 'demo()' for some demos, 'help()' for on-line help, or
> | 'help.start()' for an HTML browser interface to help.
> | Type 'q()' to quit R.
> | [Previously saved workspace restored]
> | > library(spgrass)
> | Loading required package: sp
> | Loading required package: XML
> | GRASS GIS interface loaded with GRASS version: GRASS 7.0.0beta3 (2014)
> | and location: spearfish60_grass7
> | > example(spgrass)
> | spgrss> if (nchar(Sys.getenv("GISRC")) > 0) {
> | spgrss+   require(rgdal)
> | spgrss+   soilsph <- readRAST("soils.ph", ignore.stderr=TRUE, plugin=FALSE)
> | spgrss+   summary(soilsph)
> | spgrss+   grd <- gmeta2grd(ignore.stderr=TRUE)
> | spgrss+   grd
> | spgrss+   set.seed(1)
> | spgrss+   pts <- spsample(soilsph, 200, "random")
> | spgrss+   smple <- SpatialPointsDataFrame(pts, data=over(pts, soilsph))
> | spgrss+   summary(smple)
> | spgrss+   writeVECT(smple, "sp_dem", v.in.ogr_flags="overwrite", ignore.stderr=TRUE)
> | spgrss+   bugsDF <- readVECT("bugsites", ignore.stderr=TRUE, mapset="PERMANENT")
> | spgrss+   summary(bugsDF)
> | spgrss+   vInfo("streams", ignore.stderr=TRUE)
> | spgrss+   vColumns("streams", ignore.stderr=TRUE)
> | spgrss+   vDataCount("streams", ignore.stderr=TRUE)
> | spgrss+   streams <- readVECT("streams", type="line,boundary",
> | spgrss+     remove.duplicates=FALSE, ignore.stderr=TRUE, plugin=FALSE)
> | spgrss+   summary(streams)
> | spgrss+ }
> | Loading required package: rgdal
> | rgdal: version: 0.9-1, (SVN revision 518)
> | Geospatial Data Abstraction Library extensions to R successfully loaded
> | Loaded GDAL runtime: GDAL 1.11.1, released 2014/09/24
> | Path to GDAL shared files: /usr/local/Cellar/gdal/1.11.1_3/share/gdal
> | Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
> | Path to PROJ.4 shared files: (autodetected)
> | Command: v.in.ogr
> | Description: Imports vector data into a GRASS vector map using OGR library.
> | Keywords: vector, import, OGR
> | Parameters:
> |   name: dsn, type: string, required: yes, multiple: no
> | [Examples:
> | 		ESRI Shapefile: directory containing shapefiles
> | 		MapInfo File: directory containing mapinfo files]
> |   name: layer, type: string, required: no, multiple: yes
> | [Examples:
> | 		ESRI Shapefile: shapefile name
> | 		MapInfo File: mapinfo file name]
> |   name: output, type: string, required: no, multiple: no
> |   keydesc: name, keydesc_count: 1
> | [Name for output vector map]
> |   name: spatial, type: float, required: no, multiple: yes
> |   keydesc: xmin,ymin,xmax,ymax, keydesc_count: 4
> | [Format: xmin,ymin,xmax,ymax - usually W,S,E,N]
> |   name: where, type: string, required: no, multiple: no
> |   keydesc: sql_query, keydesc_count: 1
> | [Example: income < 1000 and inhab >= 10000]
> |   name: min_area, type: float, required: no, multiple: no
> |   default: 0.0001
> | [Smaller areas and islands are ignored. Should be greater than snap^2]
> |   name: type, type: string, required: no, multiple: yes
> |   default:
> | [Optionally change default input type]
> |   name: snap, type: float, required: no, multiple: no
> |   default: -1
> | ['-1' for no snap]
> |   name: location, type: string, required: no, multiple: no
> | [Name for new location to create]
> |   name: cnames, type: string, required: no, multiple: yes
> | [List of column names to be used instead of original names, first is used for category column]
> |   name: encoding, type: string, required: no, multiple: no
> | [Overrides encoding interpretation, useful when importing ESRI Shapefile]
> |   name: key, type: string, required: no, multiple: no
> | [If not given, categories are generated as unique values and stored in 'cat' column]
> | Flags:
> |   name: f [List supported OGR formats and exit] {TRUE}
> |   name: l [List available OGR layers in data source and exit] {TRUE}
> |   name: c [Do not clean polygons (not recommended)] {FALSE}
> |   name: 2 [Useful if input is 3D but all z coordinates are identical] {FALSE}
> |   name: t [Do not create attribute table] {FALSE}
> |   name: o [Override dataset projection (use location's projection)] {FALSE}
> |   name: r [Limit import to the current region] {FALSE}
> |   name: e [Also updates the default region if in the PERMANENT mapset] {FALSE}
> |   name: w [Change column names to lowercase characters] {FALSE}
> |   name: i [Create the location specified by the "location" parameter and exit. Do not import the vector data.] {FALSE}
> |   name: overwrite [Allow output files to overwrite existing files] {FALSE}
> |   name: help [Print usage summary] {FALSE}
> |   name: verbose [Verbose module output] {FALSE}
> |   name: quiet [Quiet module output] {FALSE}
> | Error in insert_required(pcmd = pcmd, parameters = parameters, pt = pt,  :
> |   required parameters with no defaults missing: dsn
> | > traceback()
> | 10: stop(paste("required parameters with no defaults missing:", paste(nadefnms1,
> |         collapse = " ")))
> | 9: insert_required(pcmd = pcmd, parameters = parameters, pt = pt,
> |        req = req, suppress_required = suppress_required)
> | 8: doGRASS(cmd, flags = flags, ..., parameters = parameters, echoCmd = echoCmd,
> |        legacyExec = legacyExec)
> | 7: execGRASS("v.in.ogr", flags = v.in.ogr_flags, input = GDSN, output = vname,
> |        layer = LAYER, ignore.stderr = ignore.stderr)
> | 6: writeVECT(smple, "sp_dem", v.in.ogr_flags = "overwrite", ignore.stderr = TRUE) at Rex5d28289dfd2d#18
> | 5: eval(expr, envir, enclos)
> | 4: eval(ei, envir)
> | 3: withVisible(eval(ei, envir))
> | 2: source(tf, local, echo = echo, prompt.echo = paste0(prompt.prefix,
> |        getOption("prompt")), continue.echo = paste0(prompt.prefix,
> |        getOption("continue")), verbose = verbose, max.deparse.length = Inf,
> |        encoding = "UTF-8", skip.echo = skips, keep.source = TRUE)
> | 1: example(spgrass)
> | > version
> |                _
> | platform       x86_64-apple-darwin14.1.0
> | arch           x86_64
> | os             darwin14.1.0
> | system         x86_64, darwin14.1.0
> | status
> | major          3
> | minor          1.2
> | year           2014
> | month          10
> | day            31
> | svn rev        66913
> | language       R
> | version.string R version 3.1.2 (2014-10-31)
> | nickname       Pumpkin Helmet
> | > sessionInfo()
> | locale:
> | [1] en_US.UTF-8/en_US.UTF-8/en_US.UTF-8/C/en_US.UTF-8/en_US.UTF-8
> | attached base packages:
> | [1] stats     graphics  grDevices utils     datasets  methods   base
> | other attached packages:
> | [1] rgdal_0.9-1   spgrass_0.1-0 XML_3.98-1.1  sp_1.0-16
> | loaded via a namespace (and not attached):
> | [1] grid_3.1.2      lattice_0.20-29 tools_3.1.2
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
