[GRASS-stats] Towards spgrass7
Rainer M Krug Rainer at krugs.de
Mon Jan 26 01:32:24 PST 2015
Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> writes:
> On Thu, 15 Jan 2015, Markus Neteler wrote:
>> Dear Roger,
>> On Thu, Jan 15, 2015 at 1:10 PM, Roger Bivand <Roger.Bivand-aX1nC9UfZf8 at public.gmane.org> wrote:
>>> Dear Markus,
>>> Good to hear you are well! Great that RC1 is ready!
>> Yeah, it took us a while but the latest cleanup efforts where really
>> important. I expect that we will proceed from RC1 to final release
>> rather fast (finally!).
>>> Yes, I guess it would be sensible to condition on version in these cases, so
>>> first add comments for hard-coded flags and options (there are also some
>>> changes in type, I think). In addition, bin_out_win in parseGRASS() needs
>>> updating and/or conditioning on version, and the logic for handling where
>>> Python scripts are found should be looked at.
>> Yes, fine.
>>> You do not (yet) have commit rights on:
>>> https://r-forge.r-project.org/projects/rspatial/ where spgrass6 lives.
>> I have now registered on R-Forge.
>>> Two alignments: should GRASS5 support (GRASS packages) be dropped (yes)?
>> Yes, dropped.
>>> Should spgrass6 be forked into (new) spgrass which supports >= 7, and leave
>>> spgrass6 for 6.*?
>> I'd support to fork in order to not have too many conditions in the code.
>>> If fork, is SVN on R-Forge OK?
>> Yes.
> After forking, as of now:
> install.packages("spgrass", repos="http://R-Forge.R-project.org")
> installs the "new" package for GRASS 7. Function names are now without
> the trailing 6 to avoid confusion, and all examples run correctly in
> Spearfish in GRASS 7.0 RC1.
> Could someone please run the examples in Spearfish in GRASS 7.0 RC1 on
> Windows after installing the Windoes spgrass binary (R 3.1) from
> R-Forge, and report back?
> Could someone please install spgrass from source on OSX (pre-Yosemite
> and Yosemite), run the examples in Spearfish, and report back?
> The existing spgrass6 does not work with GRASS 7 following recent
> changes in GRASS parameter names - it may be modified either to permit
> these, or to remove GRASS 7 conditions, leaving it just for GRASS 6.
I like the simplicity for the user of using spgrass for all versions, but I also see
the simplicity for maintenance when splitting the packages.
Would it be possible to
a) create an spgrass7 package and
b) create an spgrass package which loads the spgrassX package
corresponding to the grass version specified or automatically detected?
This could be the best solution for users as well as developers?
I might have some time this week - I'll do some cleaning up of the
leftovers of grass 6 in the spgrass code.
To keep the consistency, I would recommend to rename spgrass in spgrass7
(in line with spgrass6) as soon as possible.
Cheers,
Rainer
> Best wishes,
> Roger
>> Best wishes,
>> Markus
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150126/ef75f7b3/attachment.pgp>
More information about the grass-stats mailing list
