[GRASS-stats] rgrass7: readVECT() issue with drivers other than ESRI Shapefile
Roger Bivand
Roger.Bivand at nhh.no
Thu Jun 18 01:28:56 PDT 2015
Dear Markus,
You have commit rights, so please consider that route. Before committing,
I increment Version: in rgrass7/DESCRIPTION, and run:
R CMD build rgrass7
in spgrass/pkg, creating rgrass7_0.1-*.tar.gz, then start GRASS 7 in the
example location (NC basic), and run:
R CMD check --run-dontrun --run-donttest rgrass7_0.1-*.tar.gz
If it passes without obvious problems caused by the changes made, I
commit.
It may be worth adding a suitable example to the help page in man/,
guarded in case some platform doesn't have the required driver on the
rgdal side. I think that GML and GeoJSON are problematic because of the
binary-string-binary conversions for coordinates, but we need working
cases to start with.
Of course, if it is more convenient for you, a diff for me to patch in
would also be fine.
Thanks for pushing (not a git pun) this!
Best wishes,
Roger
On Thu, 18 Jun 2015, Markus Neteler wrote:
> Dear Roger,
> On Wed, Jun 17, 2015 at 2:36 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> geonames <- readVECT("mygeonames", driver="GML")
>> Error in paste(gtmpfl1, shname, sep = .Platform$file.sep) :
>> object 'shname' not found
> I fixed it locally. Do you want a diff or me committing it?
> Best
> Markus
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats
