[GRASS-stats] rgrass7: readVECT() issue with drivers other than ESRI Shapefile
Markus Neteler
neteler at osgeo.org
Thu Jun 18 03:31:12 PDT 2015
Dear Roger,
On Thu, Jun 18, 2015 at 11:51 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> On Thu, 18 Jun 2015, Markus Neteler wrote:
>> Should I put 0.2-0 or 0.1-1 ?
> 0.1-1, as this would be a small correction of an existing functionality.
Fine, commited as revision 32.
Concerning the GRASS GIS -R data exchange:
GML also not perfect - the yet uncommited local change is to use
"SQLite" rather than SHAPE since it also preserves the projection
metadata (which GML doesn't). Works smoothly here so far.
> I'll fix this once you commit; it is protected by \dontrun{} in the help
> file examples, but --run-dontrun overrides that. CRAN often uses
> --run-dontrun --run-donttest to be sure that the code included in these
> exceptions is valid. I need to find a way to bracket this properly.
> Sorry, I should have tried myself first!
No problem at all!
best,
Markus
More information about the grass-stats
