[GRASS-stats] Mapset and layer names in readVECT using GRASS GDAL plugin
Ahmadou Dicko
dicko.ahmadou at gmail.com
Thu Jun 18 04:18:47 PDT 2015
I'm trying to use the direct OGR access to GRASS vector using plugin
through the rgrass7 package in R but I have some issues with the
mapset argument.
Here are the steps to reproduce the bug using the nc_basic_spm_grass7
GRASS location and user1 mapset.
Within the GRASS session, we launch R
library(rgrass7)
v <- readVECT("geonames", plugin = TRUE)
Error in .read_vect_plugin(vname = vname, layer = layer, type = type, :
object 'mapset' not found
One way to fix this, is to add a mapset argument to .read_vect_plugin
and set it by default to the same argument in the readVECT function.
### Example of fix
readVECT <- function(..., mapset = NULL, ...) {
if (plugin) {
res <- .read_vect_plugin(..., mapset = mapset, ...)
But once this problem solved, another one appears. This one, need
confirmation though. Using the GRASS GDAL plugin, I can't open a GRASS
vector without using the layer name. I am aware that we can use the
layer number using other driver (Shapefiles, GML, etc) but I looks
like (at least in my setup) that I can't open it without giving the
layer name.
I modified rgrass7:::.read_vect_plugin and named it .read_vect_plugin2
and added a mapset argument (to correct the first bug).
### Reproducing the error
sss <- strsplit(packageDescription("rgdal")$Version, "-")[[1]]
class(
.read_vect_plugin2("geonames",
mapset = NULL,
layer = 1L,
sss = sss,
ignore.stderr = TRUE,
pointDropZ = TRUE)
Error in ogrInfo(dsn = dsn, layer = layer, encoding = encoding,
use_iconv = use_iconv, :
Cannot open layer
class(
mapset = NULL,
layer = "geonames",
sss = sss,
pointDropZ = TRUE)
[1] "SpatialPointsDataFrame"
attr(,"package")
[1] "sp"
Please can you confirm that it is a feature of the plugin to have the
real name instead of the layer number ?
Nonetheless, one way to fix this is to add a call to
rgdal::ogrListLayers in the rgrass7:::.read_vect_plugin
dsn <- paste(gg$GISDBASE, gg$LOCATION_NAME, mapset, "vector",
vname[1], "head", sep = "/")
layers <- rgdal::ogrListLayers(dsn = dsn)
Using this approach we can have the layer names and use it in readOGR.
I hope that I described it clearly.
Best regards,
Info and spec
Linux:
Linux dickoa 4.0.5-1-ARCH #1 SMP PREEMPT Sat Jun 6 18:37:49 CEST 2015
x86_64 GNU/Linux
GRASS:
version=7.1.svn
date=2015
revision=65487
build_date=2015-06-16
build_platform=x86_64-unknown-linux-gnu
GDAL:
GDAL 1.11.2, released 2015/02/10
R:
sessionInfo()
R version 3.2.1 RC (2015-06-14 r68519)
Platform: x86_64-unknown-linux-gnu (64-bit)
Running under: Arch Linux
locale:
[1] LC_CTYPE=en_US.UTF-8 LC_NUMERIC=C
[3] LC_TIME=en_US.UTF-8 LC_COLLATE=en_US.UTF-8
[5] LC_MONETARY=en_US.UTF-8 LC_MESSAGES=en_US.UTF-8
[7] LC_PAPER=en_US.UTF-8 LC_NAME=C
[9] LC_ADDRESS=C LC_TELEPHONE=C
[11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C
attached base packages:
[1] stats graphics grDevices utils datasets methods
[7] base
other attached packages:
[1] rgdal_0.9-3 rgrass7_0.1-0 XML_3.98-1.2 sp_1.1-1
loaded via a namespace (and not attached):
[1] tools_3.2.1 grid_3.2.1 lattice_0.20-31
Ahmadou H. DICKO
statistician economist (Ingénieur Statisticien Économiste)
PhD candidate in Climate change economics
Faculty of economics and managment - Cheikh Anta Diop University
West African Science Service Center on Climate Change and Adaptated
Land Use (WASCAL)
Center for Development Research (ZEF) - University of Bonn
email : ahmadou.dicko at ucad.edu.sn
twitter : @dickoah
github : github/dickoa
tel : +221 33 827 55 16
portable: +221 77 123 81 69
More information about the grass-stats
