[GRASS-stats] readRAST and mapset consistency with gdal plugin
Rainer M Krug
Rainer at krugs.de
Thu Jun 18 09:33:48 PDT 2015
Ahmadou Dicko <dicko.ahmadou at gmail.com> writes:
> Dear all,
> I'm testing the GRASS GDAL pluging using the rgrass7 package and I
> have some issues with the readRAST function with the mapset argument.
> Inside readRAST we have a .read_rast_plugin core function to read the
> raster using the plugin that supposed to share the same argument as
> readRAST.
> However, inside .read_rast_plugin, the mapset argument is always NULL,
> since we have a mapset argument in readRAST should not the these two
> arguments be the same.
My fault - I forgot the mapset.
I just uploaded a fix - Thanks Ahmadou - exactly as you suggested.
Cheers,
Rainer
> To illustrate what I mean
> This what we have:
> readRAST <- function(..., mapset = NULL, ...) {
> .read_rast_plugin(..., mapset = NULL, ...)
> This is what I think we should have:
> .read_rast_plugin(..., mapset = mapset, ...)
> Here are the steps to reproduce the bug:
> I used the nc_basic_spm_grass7 location and user1 mapset.
> In GRASS
> g.copy raster=elevation at PERMANENT,elevation
> g.region raster=elevation
> Then we launch R within the GRASS session
> library(rgrass7)
> r <- readRAST("elevation", plugin = TRUE, mapset = "user1")
> /home/ahmadou/GIS/GRASS/grassdata/nc_basic_spm_grass7/user1/cellhd/elevation
> has GDAL driver GRASS
> and has 1350 rows and 1500 columns
> Warning message:
> statistics not supported by this driver
> ### Still have 'user1' in metadata
> r <- readRAST("elevation", plugin = TRUE, mapset = "PERMANENT")
> Warning message:
> With the corrected version we have:
> ### Now we have 'PERMANENT' in the path (metadata)
> r <- readRAST2("elevation", plugin = TRUE, mapset = "PERMANENT")
> /home/ahmadou/GIS/GRASS/grassdata/nc_basic_spm_grass7/PERMANENT/cellhd/elevation
> Warning message:
> I don't have commit right, should I provide a diff file ?
> Best,
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20150618/373fab65/attachment.pgp>
More information about the grass-stats
