[GRASS-stats] Using GRASS addons in R on Windows
Roger Bivand
Roger.Bivand at nhh.no
Tue Jan 12 23:25:45 PST 2016
On Tue, 12 Jan 2016, Roger Bivand wrote:
> On Tue, 12 Jan 2016, Markus Neteler wrote:
>> On Tue, Jan 12, 2016 at 8:24 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> > On Tue, 12 Jan 2016, Helmut Kudrnovsky wrote:
>> > > confirmed, it works now.
>> > > great, thanks!
>> > OK, thanks, as I've also made progress on the other problem (using
>> > temporary
>> > SQLite files for vector transfer under Windows), I've submitted to CRAN.
>> > Anyone who installed the 0.1-4 versions for testing will need to install
>> > the
>> > CRAN version when/if it appears.
>> That's great, thanks for discovering and solving!
> On CRAN now (source package), Windows binary will follow. Thanks for help in
> checking - if the *.py scripts all have *.bat in the locations checked, they
> should be found.
> Does the order of the system and user bin folders matter? Should we care if
> the addons are duplicated?
Maybe released too fast, unfortunately. For use of R in a running GRASS
session with addons, this version should be fine.
However, it will not work for initGRASS(), which does not set
GRASS_ADDON_BASE or GRASS_ADDON_PATH.
Where should I look to see where the correct values are stored on Unix
(Linux and OSX?) and Windows? I see: GRASS_ADDON_BASE as GNU/Linux is
$HOME/.grass7/addons, on MS Windows $APPDATA\GRASS7\addons in:
https://grass.osgeo.org/grass70/manuals/variables.html
Is %APPDATA% a predictable location on Windows?
What happens if the user sets prefix= in g.extension?
On Windows, adding GRASS_ADDON_BASE\bin to the PATH is sufficient (because
all scripts in /scripts have a matching *.bat in /bin. On Unix, we need
both /scripts (for Python scripts) and /bin for compiled extensions. Do we
need toolboxes?
Best wishes,
Roger
> Best wishes,
> Roger
>> Markus
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats
