[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky
hellik at web.de
Wed Nov 16 05:31:48 PST 2016
Roger Bivand wrote
> On Tue, 15 Nov 2016, Anna Petrášová wrote:
>> Hi,
>> I installed latest R on fresh Windows 10, then I installed several
>> packages into my personal library, then I installed standalone GRASS
>> GIS 7.3, and when I run R from GRASS session, it does not see the
>> installed packages. .libPaths() called from GRASS session indeed does
>> not show the path to the personal library. I installed the packages
>> again in GRASS session and then it's OK. Any idea why this happens and
>> how to avoid that?
> No idea, only you can reproduce what you are doing. Do you mean 7.3, the
> development version? Try the 7.0 and 7.2 versions, and compare to see
> which environment variables may not be being transferred (R_LIBS probably)
> in GRASS 7.3. Are you running R in a Windows terminal (if such
> exists in Windows 10) inside GRASS, or in the command line in the
> GRASS GUI? If the latter, has this changed?
tested with winGRASS7.2.svn standalone installer
System Info
GRASS version: 7.2.svn
GRASS SVN revision: r69794
Build date: 2016-11-13
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200
in the winGRASS-provided windows console:
Cleaning up temporary files...
Starting GRASS GIS...
WARNING: Concurrent mapset locking is not supported on Windows
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.2.svn (r69794)
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Command Shell
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Users\test>R
R version 3.3.1 (2016-06-21) -- "Bug in Your Hair"
Copyright (C) 2016 The R Foundation for Statistical Computing
Platform: x86_64-w64-mingw32/x64 (64-bit)
R is free software and comes with ABSOLUTELY NO WARRANTY.
You are welcome to redistribute it under certain conditions.
Type 'license()' or 'licence()' for distribution details.
R is a collaborative project with many contributors.
Type 'contributors()' for more information and
'citation()' on how to cite R or R packages in publications.
Type 'demo()' for some demos, 'help()' for on-line help, or
'help.start()' for an HTML browser interface to help.
Type 'q()' to quit R.
> q()
Save workspace image? [y/n/c]: n
C:\Users\test>echo %R_LIBS%
%R_LIBS%
I've implemented the R-winGRASS-connecting for the standalone installer by
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/external/rbatch
https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/external/rbatch/R.bat
%R_LIBS% isn't listed there.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296042.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats
