[GRASS-stats] rgrass7 is not loading
Roger Bivand
Roger.Bivand at nhh.no
Mon Oct 3 08:23:04 PDT 2016
The OP replied off-list 20/9 that:
"I'm working on win7 home professional.
It's the latest r version (3.3.0) and native grass 7.0.4.
The rgrass7 package is the latest, downloaded yesterday. In the single r session it works and reports that grass is not running.
But if i start it in the grass session i get this error.
It seems that there are any old grass r bindings which uses the namespaces needed from the package.
Until yesterday it worked fine...
I searched for this issue, founded similar reports, but no solutions. Am"
Using Windows 7 Enterprise and R 3.3.0 and R 3.3.1, GRASS 7.0.4, and rgrass7 0.1-7 and 0.1-8, I see no issues and cannot reproduce it. Could other users of Windows (I am not a Windows user) please report whether this loading error is specific to the OP (and another person who contacted me offlist). Do not write to me offlist, only the list collectively is likely to resolve this.
Roger
Roger Bivand
Norwegian School of Economics
Helleveien 30, 5045 Bergen, Norway
________________________________________
Fra: grass-stats [grass-stats-bounces at lists.osgeo.org] på vegne av Roger Bivand [Roger.Bivand at nhh.no]
Sendt: 19. september 2016 9:53
Til: Norbert Zirps
Kopi: grass-stats at lists.osgeo.org
Emne: Re: [GRASS-stats] rgrass7 is not loading
On Mon, 19 Sep 2016, Norbert Zirps wrote:
> Dear grass users,
> since today I’ve the following problem:
First problem, unkown OS. Guess Windows (CP1252??) from the odd characters
in your email, unkown version. Unknown R version and unkown rgrass7
version. No other reports of issues that are known. Are you using OSGeo4W
GRASS or native GRASS? That shouldn't matter, rgrass7 will load with no
GRASS present.
Roger
> starting rgrass7 package in R in the grass7 console I get the following error message:
>> library(rgrass7)
> Lade n├Âtiges Paket: sp
> Lade n├Âtiges Paket: XML
> Error : .onAttach in attachNamespace() f├╝r 'rgrass7' fehlgeschlagen,
> Details:
> Aufruf: if (class(t0) != "try-error" && is.character(t0) && nchar(t0) >
> Fehler: Fehlender Wert, wo TRUE/FALSE n├Âtig ist
> Fehler: Laden von Paket oder Namensraum f├╝r 'rgrass7' fehlgeschlagen
> I tried the following options:
> New installation of GRASS7 and R
> Updated all packages in R
> Installed the package rgrass7 on both sides, in an single R Session and also in the R Session inside the GRASS console,
> But nothing works.
> Is it possible to fix this?
> Is there a way to set the namespaces for R or to repair them?
> By the way: The same problem seems to be at v.krige in the GUI. I never get this addon to work and need to use the kriging interpolation methods.
> Thank you for your help,
> kind regards, Norbert Zirps.
> Norbert Zirps
> Reichenstraße 14
> 02625 Bautzen
> mobil 015774938930
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
http://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
http://depsy.org/person/434412
More information about the grass-stats
